Fuel leak - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-22-2013, 01:21 PM Thread Starter
01Crewcab7.3's Avatar
Fuel leak
I have a fuel leak that just started from the rear tank. It's dripping down the spare tire onto the ground it only does it sometimes not always. I haven't had time to crawl under the truck and look yet I just wanted to know if you guys had any suggestions before I dug into it. I haven't added any fuel to the rear tank due to the leak but it still leaks, so I'm thinking it might be the selector valve? I'm not sure though. Thanks in advance for any help you guys can give me.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #2 of 13 Old 10-22-2013, 01:33 PM
erics diesel's Avatar
the selector valve is under the cab.
how much fuel is in the tank?
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 13 Old 10-22-2013, 03:17 PM
Quoted: 48 Post(s)
4x4 or 2WD?
madpogue is offline
post #4 of 13 Old 10-22-2013, 03:17 PM Thread Starter
I ran it low the last time I used it. About 2 weeks ago. Haven't added any since. I figured maybe 2 gallons. By now, I don't know how there could be any left. It has been leaking 2' round puddles for the last week or so.
Tim
post #5 of 13 Old 10-22-2013, 03:18 PM Thread Starter
Originally Posted by madpogue View Post
4x4 or 2WD?
It's the OBS in my sig, 4x4.
Tim
post #6 of 13 Old 10-22-2013, 03:48 PM
Quoted: 48 Post(s)
Sigs can be turned off.
Bet a nickel the bottom of the tank is rusted. When you drop the spare, you'll see that there are NO tank straps. The skid plates are holding up the tank. Provides a nice place for wet gunky road crud to build up where the tank sits on the plates, and the wetness eventually rusts the tank.
madpogue is offline
post #7 of 13 Old 10-22-2013, 03:54 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i'm with madpogue on this one
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 13 Old 10-22-2013, 03:56 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Does it leak when the truck is running and on the rear tank? My feed and pickup tubes on the fuel pickup unit were rusted and leaking.
dirtcrew51m is offline
post #9 of 13 Old 10-22-2013, 04:23 PM
Chop's Avatar
To the OP , I just finished replacing the rear tank for the very same reason .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #10 of 13 Old 10-22-2013, 10:02 PM Thread Starter
Thanks guys. I'll check it out in depth this weekend. Now I have a better idea what to look for.
Tim
