94.5 7.3 powerstroke seal for motor oil pan - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-22-2013, 06:53 AM Thread Starter
I notice that my oil pain seal/gasket is leaking, but I do not want to pull the motor can a person pull the transmission, it's a five speed standard f350 then take the oil pan out and slide it out towards the back any help or advice would be freaky appreciated!
7treestroker is offline
post #2 of 5 Old 10-22-2013, 07:55 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
The motor needs to be lifted several inches for the pan to clear the crankshaft. I use this to great effect as long as the leak is not where there are moving parts (rear seal mainly). Get the engine hot, clean the area well with brake cleaner, let the cleaner evaporate, spray on a very thin coat, wait 10 minutes and repeat 2 more times. If it starts to drip you used too much. Wait longer.
Sealants : Permatex® Spray Sealant Leak Repair
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 5 Old 10-22-2013, 05:09 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Your leak may not be this, but check anyway: On the 94.5's the flywheel inspection cover can wear a hole in the oil pan (and it did on mine). Mine only leaked when running. You can get an updated cover or grind off the lip on the original. I ended up cleaning the area really well with Brakecleen and then filling the "slot" with JB Putty. I then coated it with 3 coats of POR-15 and it did not leak again. Cheers!
Patrick Feeley is offline
post #4 of 5 Old 10-23-2013, 05:44 PM
I have the same small leak on mine if you can find where exactly the leak is .. Like I did I took the time and just real carefully scrapped some of the rtv out and cleaned it up and applied a nice new bead of rtv and now I have no leak
Sparchuleta is offline
post #5 of 5 Old 10-27-2013, 04:11 PM
TRUKK30's Avatar
I had to raise the engine quite a bit to clear the pickup, mains, etc. It is a P.I.A. I got rid of the stock dipstick tube adapter and welded on a steel one. No more O-ring. There is a big O-ring on the inside of the pan. As it swells over the years it causes the nut on the inside of the pan (O-ring is under the nut) to bend. I couldn't believe how much force an O-ring can apply! Also, Ford uses a gray rtv to seal the pan, no pan gasket.
TRUKK30 is offline
