CCLB Driveshaft Help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-21-2013, 11:06 AM Thread Starter
I'm hoping i can find a few CCLB owners to do me a favor and crawl under there truck and take a picture from under the Tcase looking towards the rear diff so I can see if there is any lateral angle on your driveshaft? Mine is kicked over towards my front tank and under load the center yolk is actually smashing into the skid plate. I'm trying to find a way to get my carrier bearing over to the left(when viewed from the point of view stated above) Thanks guys.
matt-jenkins is offline
post #2 of 6 Old 10-21-2013, 01:33 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sounds like you mite need a carrier bearing, sorry mine is currently a 2wd CClb tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 10-21-2013, 01:45 PM Thread Starter
Just had a brand new bearing, center U joint and the front weld yolk installed on the rear drive shaft along with balance on thursday.
post #4 of 6 Old 10-21-2013, 01:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Hmm, well hopefully someone with 4x4 can chime in soon to help you a bit, but doesn't seem like the drive shaft is supposed to kick out in any direction
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 10-21-2013, 02:53 PM Thread Starter
Transmission mount was the culprit, about to crawl under the truck and swap it out as we speak.
post #6 of 6 Old 10-21-2013, 04:27 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Take a pick of your drive shaft set up and post it please. I'm curious
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
