water in fuel help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-20-2013, 03:02 PM Thread Starter
MDdiesel's Avatar
water in fuel help
A few weeks back I had the WIF light come on. I drained the fuel bowl and changed out the filter and that was it. Now a few days ago it came back on again and there is infact water in the bottle I drained from the fuel bowl. Im running Power Service additive currently. I started after the first time the WIF light came on. Any idea on why? Poor fuel quality? What kind of additive should I run to help remove that fuel from the tank, short of dropping and draining the tank…
Thanks.
'97 f-350 rclb auto 4x4
Mods- Baby Swamp injectors, Tymar intake, Dieselsite coolant filter, TS 6pos chip,
3 pillar gauges - pyro,boost,trans temp, 3in dp, 4in exhaust, 8in Catstack, 4.10 gears.
MDdiesel is offline
post #2 of 3 Old 10-20-2013, 03:39 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Siphon fuel all from the tank (if theres a siphon proof block in your filler line you should take something off the top of the tank and do it that way), fill it up with new fuel, run the appropriate amount of Diesel Kleen through it, and it should help.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #3 of 3 Old 10-20-2013, 04:54 PM
bucwheat's Avatar
There are additives that will dissipate water from diesel.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
