Help! Junk turbo, what to do? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-20-2013, 01:26 PM Thread Starter
M.F.E.'s Avatar
So this week alone I have thrown $750 of my extremely limited budget at the truck and in the process of doing glow plugs I found this and believe it's junk because of it. IM trying to take the truck on a snowboarding trip next month and also need to have the front axle resealed what are your thoughts?
Sad day to see it leave like that!
M.F.E. is offline
post #2 of 18 Old 10-20-2013, 02:19 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Search the local salvage yards for a turbo. And check shaft play so you dont get a bad one. The axle seal should be easy to fix, where is it leaking?
dirtcrew51m is offline
post #3 of 18 Old 10-20-2013, 02:20 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Why do u say its junk?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 18 Old 10-20-2013, 02:34 PM Thread Starter
M.F.E.'s Avatar
Well I figure with that big of chunks missing from the fins it can't be good. And from the passenger side axle tube.
M.F.E. is offline
post #5 of 18 Old 10-20-2013, 02:46 PM
erics diesel's Avatar
i'm not seeing any pics or links so i have no idea what it is your looking at
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #6 of 18 Old 10-20-2013, 02:48 PM
ol_Blue97's Avatar
Axle seal? Turbo seal or the axle ? Fins missing from intake side or exhaust side?
FRANK THE TANK
post #7 of 18 Old 10-20-2013, 03:06 PM Thread Starter
M.F.E.'s Avatar
Sorry, thought it was attached
ID:	183993   Click image for larger version
M.F.E. is offline
post #8 of 18 Old 10-20-2013, 03:08 PM
you can get just the wheel and they arent that expensive and replace it with the turbo still in the truck
post #9 of 18 Old 10-20-2013, 03:24 PM
ol_Blue97's Avatar
I thought u couldn't remove the housing with the turbo in the truck. Bu yes, u can just replace the wheel, just check for shaft play and if it's bad u wil has to pull the turbo and rebuild it. It's still useable as is, u can run it until u get some cash built up
FRANK THE TANK
post #10 of 18 Old 10-20-2013, 05:01 PM
lowboy1979's Avatar
I just got done with my turbo, its a little bit of a ***** to remove but the rebuild was cheap and simple. There is not a lot of parts inside of it. Check out diesel orings.com, they have all the parts you need.
____________________________________
1997 Crew cab, Long bed, F-350, 4x4, 4:11's, Centurion package. 190,000, New Jasper Engine.
6637 Air filter.
3" down pipe with 5" strait pipe.
Tony Wildman, (Econ,Tow,
Heavy Tow, Street, Extreme,Smoke)
A-pillar autometer gauges,
Fuel regulator spring upgrade.
IDM Mod.
Snow performance Water, Meth injection.
Banks exhaust housing.
Wicked Wheel 2.
EBP delete.
Next upgrades-,Intercooler, E-Fuel
T500, Rosewood stage 2 sticks,
bigger turbo
lowboy1979 is offline
