dorman valve cover gasket - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-19-2013, 02:35 PM Thread Starter
M.F.E.'s Avatar
Has anyone used the dorman oe solutions valve cover gasket from O'Reilly auto parts? I see it comes with the under valve cover harness for 64.99. I need to do blowouts and for that price I thought it may be worth it to know im gonna have good harnesses in there instead of finding a bad harness and waiting days for a new one. Also it's only dollars more expensive than the motorcraft gasket.
Sad day to see it leave like that!
M.F.E. is offline
post #2 of 6 Old 10-19-2013, 02:40 PM
erics diesel's Avatar
i used dormans but i got them from rock auto. i think the big thing is that the wires are copper and not aluminum
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 6 Old 10-19-2013, 02:47 PM Thread Starter
M.F.E.'s Avatar
i am operating on a really tight budget so i was thinking about going with that. and i do see they have a warranty. i was just curious if they where known to be decent or junk or just basically what the word is about them.
M.F.E. is offline
post #4 of 6 Old 10-19-2013, 04:01 PM
I changed my valve cover gaskets (dorman) and the under valve cover harness along with the glow plugs in late summer 2011. I got it all from Rock Auto.......no issues. I would shop around since cash is tight, Rock Auto used to beat my part stores hands down to include shipping but lately seems like they don"t save you much, if anything at all.
97 1 ton (real truck) and 06 2500 cummins ( it's a cummins thing, NOT A DODGE thing LMAO)
BOB1997 is offline
post #5 of 6 Old 10-20-2013, 07:07 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
It can be hit or miss with them. I used them on my 94, but I prefer the factory gaskets and UVCHs. If it's all you can afford, go for it. The issues that sometines pop up are sometimes mis-wired UVCHs (wires swapped in the connector) and one guy mentioned that his connection at the gasket would go intermittent as the valvecover gasket was torqued down. Cheers!
Patrick Feeley is offline
post #6 of 6 Old 10-20-2013, 06:46 PM
I recently installed a DORMAN valve cover gasket that I bought at O'Reilly's. I'd heard about the hit-and-miss quality control, but I meter'd out each connection as well as the pigtails and they were OK.
I've only had it in for about a month, but no problems so far. Replacing them is a fairly easy job - driver's side a bit tougher - so I'm not too worried if it craps out in 6 months or so.
As for the connections and pigtails, I soldered and heat-shrunk them, as per advice I got here.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
