What's is this leaking? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-19-2013, 11:54 AM Thread Starter
M.F.E.'s Avatar
I bought a 95 f350 and it has a leak but I don't know what it is. In about 500 miles it has leaked 3/4 of a quart and seems to mainly leak during starting the truck or after shutting it of. I will attach the pictures I took of the leak.
ID:	183377   Click image for larger version
ID:	183385   Click image for larger version
Sad day to see it leave like that!
M.F.E. is offline
post #2 of 8 Old 10-19-2013, 12:03 PM
66Bronco's Avatar
Looks like the orings on the oil cooler are shot. Mine's doing the same thing.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 8 Old 10-19-2013, 12:33 PM Thread Starter
M.F.E.'s Avatar
Is that an issue, is it something I can just top off the oil occasionally or is that something that needs immediate repair and how hard is the repair.
M.F.E. is offline
post #4 of 8 Old 10-19-2013, 02:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If you don't repair it your going to have to keep buying oil
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 8 Old 10-19-2013, 03:30 PM Thread Starter
M.F.E.'s Avatar
My question is how hard is the repair, it looked hard to get to.
M.F.E. is offline
post #6 of 8 Old 10-19-2013, 08:32 PM
Its not too hard. You can get to the back three bolts where the filter is really easy. Get to the front two either from under the truck or through the wheel well. The hardest part is wiggling it out. Took me about 15 minutes and I had it out (Not counting the time it took to drain the Oil and Coolant.).
I can give you a write up if you want.
Where are you located?
williameub is offline
post #7 of 8 Old 10-19-2013, 10:17 PM
sethc24's Avatar
its not hard too do just messy.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #8 of 8 Old 11-13-2013, 01:48 PM
vandy's Avatar
If you have it I'll take it. My cooler started leaking last year when I plugged in. It's started leaking this week without plugging in. I have the Ford service manual but it's limited. Doesn't look like too big of a deal. But I just got home and have quite an oil stain on my driveway
vandy is offline
