95 Cab and Chassis with oil leak,buy or no buy - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-18-2013, 05:42 PM Thread Starter
dracula6's Avatar
I am looking a t a 1995 F350 cab and chassis 5 speed with 185000 and a flat bed. Steering is tight and everything seems good to go other than an oil leak on the front of the engine. This will be a farm truck and at 3 grand I think it is a good deal. What do you guys think?
dracula6 is offline
post #2 of 8 Old 10-18-2013, 06:11 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
depends where the leak is, could be oil pan or could be front main or could be HPOP reservoir leaking. A front leak is usually a little more involved than a rear leak as the rear is normally the drain hole for the valley. For 3 grand id buy it if its not rotted out (idk where in the world the truck is)
Trucks and parts............
kanuck15 is offline
post #3 of 8 Old 10-18-2013, 07:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I agree with this, but do you have piks of the truck to let us know the condition of the rest? Is it a small leak or a big one? Any idea where it comes from at all?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 10-19-2013, 09:25 AM Thread Starter
dracula6's Avatar
Thanks for the input!
I have no idea where the leak is coming from.
There is minor rust on the frame, but nothing a little sanding and paint won't fix. Looks like he's kept the grease fittings greased.
ID:	183313   Click image for larger version
ID:	183321   Click image for larger version
ID:	183329   Click image for larger version
ID:	183337   Click image for larger version
dracula6 is offline
post #5 of 8 Old 10-19-2013, 09:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Looks good, guessing you decided to bring her home and put some loving into the ol girl
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 8 Old 10-19-2013, 12:25 PM Thread Starter
dracula6's Avatar
No, that is from the add
dracula6 is offline
post #7 of 8 Old 10-19-2013, 02:48 PM
kanuck15's Avatar
Quoted: 10 Post(s)
looks clean yet used. Honestly for 3 grand its worth it. If I had use for a flat bed Id buy it. Unless its pissing oil out then its not a huge deal and can be tracked down as you go
kanuck15 is offline
post #8 of 8 Old 10-19-2013, 02:52 PM
Spud Monkey's Avatar
I guess my F Super Duty flatbed is worth 4k with given condition it runs with mods on it and fact it's a 5 speed.
Spud Monkey is offline
