Oil in the intake - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-18-2013, 06:12 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Oil in the intake
There is a light coating of oil in the intake, there is a small accumulation in the bulge on the silicone intake couplings, its not really wet, just enough to make the metal look wet, is this normal or am I looking to rebuild the turbo? When I had my 2000 psd, oil would occasionally drip out of the intercooler tubes if the clamps were loose.
dirtcrew51m is offline
post #2 of 3 Old 10-18-2013, 06:48 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Its normal since the crankcase breather assembly connects to the intake and the oil fumes can accumulate in the manner you mention. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 10-18-2013, 09:06 PM Thread Starter
Quoted: 6 Post(s)
Thanks. No worries then.
