OBD2? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-18-2013, 01:59 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
OBD2?
95 F250. I am looking for a good scanner, heard obs trucks might or might not be obd2, just for kicks, I plugged my Actron obd2 scanner in, came on, turned key on, linked with truck, pushed enter to read codes, no codes present, would my truck be obd2?
dirtcrew51m is offline
post #2 of 7 Old 10-18-2013, 02:09 PM
Early OBS trucks needed the PCM flashed, my 94 was the same way. from 96+ when OBDII was standard there was no need to be reflashed.
PDRdiesel_matt is offline
post #3 of 7 Old 10-18-2013, 02:29 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Auto enginuity scanner works good
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #4 of 7 Old 10-18-2013, 04:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Some scan tools work, some don't, generally the cheaper ones won't read our trucks
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 10-18-2013, 04:51 PM Thread Starter
Quoted: 6 Post(s)
I am looking at the Innova scanners, the 3120 or 3140 obd1\2 scanners.
post #6 of 7 Old 10-18-2013, 05:47 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Make sure the scanner is able to read the Ford Enhanced parameters. Most don't. SnapOn MT2500 with the correct cartridge, AutoEnginuity with the Ford bundle are some examples. Cheers!
Patrick Feeley is offline
post #7 of 7 Old 10-19-2013, 02:03 PM
dazed01's Avatar
I have to identify my truck as a 95 to use my solis scan tool. It works normally after that.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
