Higher Mileage guys might take note - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-18-2013, 06:14 AM Thread Starter
rolsmojave3's Avatar
Just a heads up, I've gone through 3 7.3s lately. One with 250K miles, manual trans, been beat most of it's life, another with 225k, auto trans all stock and the last with 270k manual trans. All of these engines were in need of crank and rod bearings. If you're pulling the pan, I would suggest pulling a cap or two and seeing what you have! All of them had good oil pressure/in good operating condition.
Another with 135k was tipped over on its side and spun 3 mains and smoked the rods, surprisingly the guy got it running and drove it one more day.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #2 of 20 Old 10-18-2013, 09:25 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm at 311k and have no problems, but if I ever decide to crack it open I would post my findings
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 20 Old 10-18-2013, 12:33 PM
HCSTROKER11's Avatar
357k runs like a dream. I guess maintenance is key.
1997 f350 4x4 off road.
353k miles
Stage 1 swamp injectors. TS chip. Leveled on 35" Federal tires and black 18 inch pro comp wheels
3" downpipe into 5" straight pipe 6" tip. (Diamond eye)
1987 Chevy 1ton lifted 24 inches on 53s. Duece and a half transfer case. Mud truck.
HCSTROKER11 is offline
post #4 of 20 Old 10-18-2013, 02:54 PM Thread Starter
All of these trucks ran like a dream too. Only pulled engines to replace oil pans
post #5 of 20 Old 10-18-2013, 03:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Why replace the oil pan?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 20 Old 10-18-2013, 03:51 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
They rust and leak up north
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #7 of 20 Old 10-18-2013, 03:52 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
might be rust if he is up north....
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #8 of 20 Old 10-18-2013, 03:52 PM
erics diesel's Avatar
The pans were probably rusting or leaking
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #9 of 20 Old 10-18-2013, 04:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Wow, only guys talking bout truck runs good are both from ga lmao, I forget about that rust issue
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 20 Old 10-18-2013, 04:59 PM
Quoted: 3 Post(s)
He lives in Wisconsin according to his profile. that is so North they kinda talk like canadians
