02 7.3 IN A 97? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-17-2013, 04:06 PM Thread Starter
Question 02 7.3 IN A 97?
Hey everyone (been awhile since I've been on here),
I have an issue/question. I have the oppertunity to get a 7.3 from an 02 truck. I want to do a slow build on a stand and put it into my 97 truck. I assume the block and heads are the same (or am I assuming wrong?). What about the the electronic stuff? Or is it as simple as transplanting the 97 electronics in the 02? THANKS for the advice, Bob
97 1 ton (real truck) and 06 2500 cummins ( it's a cummins thing, NOT A DODGE thing LMAO)
BOB1997 is offline
post #2 of 14 Old 10-17-2013, 04:38 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Block and heads would be basically the same. Unless your 97 is a California truck with splitshots, you would need to have the 97 injectors put in the 02 motor (or have your 97 PCM reprogrammed for the 02 injectors). Most of your 97 electronics should be fine on the 02 (and the 02 engine-mounted sensors should be good too). I'm sure I'm missing something (which others will gladly point out ). Cheers!
Patrick Feeley is offline
post #3 of 14 Old 10-17-2013, 05:01 PM
erics diesel's Avatar
I think the only differences are the turbo and fuel bowl
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 14 Old 10-17-2013, 05:21 PM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
fuel pump (the pads in the SD for the mechanical FP to bolt to are not drilled or tapped, should make a difference since with a build you should swap to e fuel), front accessories (ie vacuum pump), wiring harnesses, are different and the rods in an 02 are most likely PMRs
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 14 Old 10-17-2013, 05:49 PM
alaskan155's Avatar
Quoted: 65 Post(s)
here is a question i bet the op might want to know?
will the 97 down pipe work on the 02 motor/ the superduty down pipe work on the obs?
i have seen a few things on here talking about people modifying the firewall.
suck to get the motor in and not have a downpipes work, i know the inter-cooler lines will need modified from the super-duty to mount the 02 inter-cooler on the 97 since the 02 is inter-cooled and the 97 isn't
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #6 of 14 Old 10-18-2013, 03:18 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
What is Pmr?
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #7 of 14 Old 10-18-2013, 03:25 AM
the baconator
Quoted: 149 Post(s)
PMR = powdered metal rods. they were in the later superduties as opposed to forged rods. forged rods a re typically stronger. PMR is supposedly good till 400ish HP
post #8 of 14 Old 10-18-2013, 06:19 AM
rolsmojave3's Avatar
I'm helping a guy with a swap like this right now. Replacing the 97 engine with a SuperDuty. We swapped turbos and Y pipe, fuel bowl, installed fuel pump in valley, swapped front acc. brackets, swapped injectors/wiring harness. For the intake "manifolds" you may have to swap as the OBS used a smaller diameter intake.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #9 of 14 Old 10-18-2013, 02:45 PM Thread Starter
First off, thanks to all for the responses....keep them coming please. So I assume all the 97 "Stuff" bolts right back on to the SD motor? Front acc stuff, turbo, exhaust, ect, ect......? What about the down pipe/exaust? Or dont you have it back in the truck yet? I wanna keep it as a 97, know what I mean? Just use the 02 as a donor/housing so to speak. The 02 will go through a complete rebuild, with ALL 97 components.
BOB1997 is offline
post #10 of 14 Old 10-18-2013, 05:40 PM
Quoted: 15 Post(s)
Just a note: The 02 motor's cam may not have the lobe for the mechanical fuel pump, so you may need to go to an electric fuel system (whether that's the 02 system or an aftermarket/DIY system). Cheers!
