97 OBS problem AE software - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-17-2013, 08:46 AM Thread Starter
72Ford250's Avatar
Hey guys I have a question for you. I just recently bought the AE software and got it all activated and so on. I need to check my cylinder rotation velocity and here comes my problem. When going into the live data meter and go to select cylinder rotation velocity for the cylinders I only see 2-8 1 is nowhere to be found, is this normal? And then when 2-8 are shown in live data meter they all read zero,is that normal? I would think there would be at least some differences.
I do support powerstroke power
1997 250 7.3L D66 Rosewood stage II t500 HPOP crx racing intercooled Mrbp 3'' down pipe 3.5 straight diy intake (chip is at the head doctor at bdp getting tunes)
1972 250 6.4L(390 FE.(gasser)
My Dads
2007 250 6.0L (325 hp stock
72Ford250 is offline
post #2 of 5 Old 10-17-2013, 09:42 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
I'm not sure but I don't believe that is a supported monitor on our trucks but I could be wrong
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 5 Old 10-17-2013, 11:27 AM
Arcturus's Avatar
I can't help with your problem but AE should work with our trucks.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 5 Old 10-17-2013, 04:31 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I'm not seeing why you would need to measure something like that on our engines. The cylinders (or pistons) don't rotate, so their rotational velocity should always be zero. The linear velocity of the pistons would be related (for the most part) to engine RPM. Cheers!
Patrick Feeley is offline
post #5 of 5 Old 10-17-2013, 05:14 PM Thread Starter
72Ford250's Avatar
My understanding is that it is the amount of change the crank see with the fire of each cylinder. So if you have like 1%on seven cylinders and like 5% on one that would say there is a problem to be addressed in that cylinder (injector,low compression and so on)
My Dads
