No speedo, no odomometer, and blinking OD "OFF" - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-16-2013, 04:54 PM Thread Starter
Just as the title says, tonight I started up my truck, and looked down to see no odometer, then once underway noticed my speedometer working. After that I notice the truck not shifting at its normal shift intervals but nothing "awful" then the O/D off light starts illuminating, which coincides with why I do not have and overdrive.
I do not have a trans temp gauge but I do have an oversized trans pan from mag-hytec, which was warm enough to the touch that I could not comfortably keep my hand on it for more than 2-3 seconds. Not scolding hot like 200+ but based on feeling up thermostats for a living (boat mechanic) im gonna say 170-180* or so for a surface temp.
Any ideas guys? Hoping this doesn't mean its new transmission time.
1995 f-350, 108,000 miles and climbing, second motor with approximately 130,000 miles on it.
DIY Intake, stage 2 injectors from Rosewood, 3" DP to 5"side dump with a 6" Tip
HPOP, 6.0 IC (anyone have a spyder?) and E fuel to come
wakeboardin2k4 is offline
post #2 of 9 Old 10-16-2013, 05:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Vss sensor bad? Maybe lines to vss are broken, or ??? Having a scanner to read the codes your throwing would help a lot here
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 10-16-2013, 05:37 PM Thread Starter
I'll hook it up to the scanner at the marina tomorrow morning. I was fishing for the possibility that these symptoms have shown in the past with others trucks and it might stick out to someone.
Other information that I thought up after posting.
Trans fluid is at correct level, smells fine and looks good too. Fluid was change 10k ago.
Also, seems farfetched but, I was standing on the hood prior to this issue happening. I was shrink wrapping a boat and forgot my ladder. Again, sounds ridiculous but informations information.
post #4 of 9 Old 10-16-2013, 05:38 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
The vss is where id start, its the sensor in the rear diff. Also the trans issues are related to that. An automatic needs the speed sensor to shift properly
Trucks and parts............
kanuck15 is offline
post #5 of 9 Old 10-16-2013, 06:18 PM
Vss be my first guess too. Cheap enough part.
7.3l DRW F350 4x4. stock, with exception of Airbags on rear, bilstein all around and 26k 5th wheel hitch. K&N filter for good measure.
dont try this at home kids!
Unclebobsuncle is offline
post #6 of 9 Old 10-16-2013, 06:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Also the tone ring, but exact same thing happened to me when the wires on my vss melted, random gas station selling electrical tape helped me fix that issue, been like that 6 years now
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 10-17-2013, 06:59 AM Thread Starter
VSS on the top of rear diff from my research? Is that in fact correct?
post #8 of 9 Old 10-17-2013, 07:00 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yes it is.....
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 10-17-2013, 09:18 AM
Quoted: 43 Post(s)
If the odometer is blank, it's more likely NOT the VSS, but the PSOM in the dash. Or the fuse to it (see thread on other forum).
madpogue is online now
