Normal egt - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-16-2013, 01:21 PM Thread Starter
Normal egt
I have a 97 with stage 2 injectors, intake and straigh pipe. My ext temp is in the down pipe. What should normal driving egt be?
X4x4danx is offline
post #2 of 8 Old 10-16-2013, 01:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What are you reading, move it to the manifold, who's injectors are you running?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 10-16-2013, 01:42 PM Thread Starter
I just got it working again had to rewire things. It was reading about 400 today on short drive. I'm not sure who's injectors are in it. I just bought the truck a few feels ago.
X4x4danx is offline
post #4 of 8 Old 10-16-2013, 01:49 PM
the baconator
terryknight's Avatar
Quoted: 145 Post(s)
mine reads about 10x the speed. but mine is in the manifold. also have an IC, 160/100s and a D66
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 8 Old 10-16-2013, 02:21 PM Thread Starter
Ok thank you. Also a question with glow shift boost guage. My guage stays at around 8 psi at idle or when truck is off. It will work when I'm on the throttle. Any ideas on how to zero it out?
X4x4danx is offline
post #6 of 8 Old 10-16-2013, 02:22 PM Thread Starter
Did you make ic yourself or did you order one?
X4x4danx is offline
post #7 of 8 Old 10-16-2013, 02:25 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
When the EGT probe is in the down pipe never let it read more than 1000*.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 8 Old 10-16-2013, 04:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You should request paperwork on the injectors, people tend to lie about those things, either that or have them flow tested
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
