Hi from down under (Australia) - Ford Powerstroke Diesel Forum
Old 07-13-2008, 01:16 AM
Hi all
I'm a new member from australia.
just bought 97 250 4x2 with 7.3 turbo auto for towing 26ft trailer home that weighs 3.5 ton.( not a 5th wheel)
have a transmission cooler fitted, intend to intercool turbo,any other suggestions to make this a nice truck to tow with.
What sort of fuel figures should i expect?
thanks
Rod
Old 07-13-2008, 01:40 AM
welcome from texaS USA
Old 07-13-2008, 02:20 AM
285,261,190
Welcome to the org from sunny South Carolina. USA
Old 07-13-2008, 02:40 AM
Hi Powerstroke Trayback,
Welcome to the Org. from a fellow Brisbane member.
They are pretty broad questions that you ask! I have set my 250 up primarily for towing but being a later model I started a little further down the track. The intercooler is obviously your first mod, then you should look at intake and exhaust. Custom Tuners can give fuel savings as well as improved performance: most offer specific "Tow" settings.
Where in Brisbane are you? I live in Sheldon.
Old 07-13-2008, 04:20 AM
Send a message via MSN to jackgf250hdsd
Welcome to the org. from Homestead, Fl.
Old 07-13-2008, 04:57 AM
Illiana Chapter Director
Originally Posted by powerstroke trayback View Post
Hi all
thanks
Rod
from Bloomington Indiana. I had a 95 OBS truck. The first thing I would upgrade is the exhaust. I would install an aftermarket downpipe, eliminate the cat and muffler. The downpipe off the turbo is flat after it makes the bend to go behind the engine.
Old 07-13-2008, 09:08 AM
Cynic
Hi all
thanks
Rod
Howdy!
There is no real way to tell you what fuel mileage you will get, every truck is a bit different. Log your mileage during you first trip and we can go from there. Just guessing? Maybe 14-17mpg.
I can get up to 18mpg in my superduty with a travel trailer around 5 tons loaded. But, I have custom tuning and a bit of work done.
Old 07-13-2008, 01:42 PM
Hi from down under
Thank you all for your welcomes,
250 Downunder I'm in Richlands in Brisbane.
Most suggest exhaust mods etc & intercooling.
intercooling i had planed. exhaust i will be fitting 4" dump pipe remove cat
then twin 4" stacks as room behind cab is tight. Had not intended to remove muffler, how noisy does this make it 250 downunder.
Tunes for towing & programer available & where can i obtain these?
Any help appreciated
Old 07-13-2008, 01:47 PM
Other vehicle is an F250
A second Hello and Welcome from South Carolina!
You'll not find a better place to spend night after night.
