SCA test strip type for green coolant? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-15-2013, 06:11 AM Thread Starter
dracula6's Avatar
I just got home from deployment and am starting to work on my new to me 96 F350. It has green coolant in it. Do you use the same SCA test strips for all types/brands of green coolant?
dracula6 is offline
post #2 of 11 Old 10-15-2013, 08:29 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
They should all work for all green coolants. Do remember that only green coolant is designed to be used in 7.3's and SCAs can only be added to green coolant.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 11 Old 10-30-2013, 08:06 PM
Mercerks's Avatar
ummm
What are sca's? New to the diesel world....
Mercerks is offline
post #4 of 11 Old 10-30-2013, 08:41 PM
SCA= supplemental coolant additive it is an additive to help prevent corrosion and pitting from water in the coolant I believe. I'm not 100% I'm sure someone can elaborate more on that.
viggy924 is offline
post #5 of 11 Old 10-31-2013, 06:45 PM
Quoted: 44 Post(s)
It's to prevent a process called cavitation. Here is probably the most thorough, albeit drawn-out, explanation somewhere on the Internet about how the extreme heat and compression of a diesel engine can actually physically affect the engine block. It's not the water in the coolant that causes it, but a physical action of the combustion and the movement of the pistons that can damage the walls of the block. The SCA chemically prevents it.
Here's an even more elaborate explanation: Cavitation Article
Bottom line - maintain and monitor your SCA levels, or risk trashing the engine.
madpogue is offline
post #6 of 11 Old 10-31-2013, 07:08 PM
Mercerks's Avatar
Where can you buy the strips and additives???
Mercerks is offline
post #7 of 11 Old 10-31-2013, 07:49 PM
Mercerks's Avatar
Can I run a coolant that already has sca's in it or do I have to stay with a green or ford gold?
Mercerks is offline
post #8 of 11 Old 10-31-2013, 08:29 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Gold is not for our trucks. Green only. These days it's hard to find coolant without it. HD coolants will say that they have them right on the bottle ("for diesels"). It's just that the additive is spent in 15-20k miles. The additive will take you to 40-50k after needing it the first time. Or just change your coolant more often. Do not add FW-16 to gold or red coolant (or gold or red coolant to your system for that matter). ELC coolant is for motors with aluminum heads, not steel/iron heads. Test strips and FW-16 can be bought anywhere with a couple hours notice.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 11 Old 10-31-2013, 08:31 PM
Mercerks's Avatar
So I'm new, what's FW-16
Mercerks is offline
post #10 of 11 Old 10-31-2013, 09:01 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
The part number for Ford SCA (Supplemental Coolant Additive). Take it to any parts dealer and they'll cross reference it for what they can get.
Matt
'97
-Stage II trans.
BigFuel is offline
