draw from both tanks - Ford Powerstroke Diesel Forum
post #1 of 39 Old 10-13-2013, 12:35 PM Thread Starter
WYO_7.3Powerstroke's Avatar
Has anyone heard of or know if you can hook the two tanks on our obs to where it will draw from both at the same time so you dont have to constantly switch em back and forth. was thinking about maybe doing something like this after i do an electric fuel conversion. thanks
"Kleetus" 1996 Ford Power Stroke Auto, Tymar Intake, 4" Exhaust, Upgraded Torque Converter, Boost, Pyro, Tranny Gauge, TS 6 pos with TW Tunes, BB Mod, Tint
WYO_7.3Powerstroke is offline
post #2 of 39 Old 10-13-2013, 12:52 PM
sargar's Avatar
It looks to me like you have two choices, either an electric pump from one to the other and just draw from the "pumped into tank" all the time or sump both tanks and have a transfer line between the two.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 39 Old 10-13-2013, 02:12 PM
Quoted: 54 Post(s)
How would you determine to which tank the unused fuel returns, without overfilling one of them?
You also lose an important functionality of dual tanks. With dual tanks, you can run one tank down, fill it, then switch to the other tank (the one you _didn't_ just fill). Then repeat for the other tank. IOW, never fill both tanks at the same station/pump at the same time. That way, if you get a bad batch of fuel, you switch to the other tank and can at least drive the truck until you get the bad fuel issue resolved. Also, if either tank rusts and leaks, you have the other to drive on. With an automatic transfer system you lose that. Compared to flipping a switch once every 300 or so miles,.....
madpogue is offline
post #4 of 39 Old 10-13-2013, 02:51 PM
sargar's Avatar
Yeah, there are problems to be worked out, I was just throwing out a couple of options to prevent the OP from flipping a switch.
On my old '86, it defaulted to the front tank in the event of a solenoid failure, which never happened, so I would fill both tanks and run off of the rear one first.
sargar is offline
post #5 of 39 Old 10-13-2013, 03:02 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
You also have to watch if one tank runs out, the pump will draw from the empty tank, to successfully do this you will have to have to install a balance tube between the tanks.
dirtcrew51m is offline
post #6 of 39 Old 10-13-2013, 05:32 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
How does a balance tube work
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #7 of 39 Old 10-13-2013, 06:13 PM
sargar's Avatar
Basically a fuel line ran between the two tanks, from the bottom of them.
sargar is offline
post #8 of 39 Old 10-13-2013, 06:16 PM
RedneckYankee's Avatar
Balance tube is just what it is. It's a tube between the two tanks. Liquid will seek its own level problem is like on my truck front tank is 15 gals and rear is 10 gals so instead of being able to have 25 gals you can only have 20 gals otherwise the rear tank overfills. You would have to put a tee in the balance tube inorder to draw from both tanks equally.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #9 of 39 Old 10-13-2013, 06:20 PM
I think it would be easier to modify tanks with a second float with end switches to swap tanks at a predetermined level automatically.
David
Dash Boss Monitor
Blue Spring Upgrade
No Kitty
4" Straight piped
Studded
1996 F250 XCLB 4x4
post #10 of 39 Old 10-13-2013, 06:22 PM
sargar's Avatar
Or just run it as Ford designed it.
Anyone else notice that the OP hasn't been back?
sargar is offline
