96 truck with 97 motor swap - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-13-2013, 11:12 AM Thread Starter
shoopie's Avatar
So the original motor in my 96 took a crap and i am in the process of tearing down my 97 parts motor for rebuild and swap in. For some of the pros out there... what are the differences between the 96 and 97? I know some of the sensors and plugs are different but will i be able to use the 96 wiring harness? I already have a 97 computer in it. will i need to change the idm? just looking for a more experienced opinion. Thanks
1996 RCLB 7.3L auto
ARP Head studs, 3" DP, 5" stack, Riff Raff 6637, Isspro ev2 gauges,
Motor is on the stand getting rebuilt with some extra goodies...stay tuned
East Hampton, NY
shoopie is offline
post #2 of 5 Old 10-13-2013, 11:25 AM
Pwnm30rdi3's Avatar
Late model 97's have 10 bolts in the intake plenums instead of 8. If you have 10 bolts holding on your intake plenum, this means you have the SuperDuty heads.
This makes it way easier to upgrade to 3" billet plenums, which might I add is an awesome upgrade, imo.
Most of the diesel performance shops don't carry 3" billet plenums for the 8 bolt style due to lack of demand.
Besides that, there really are no major differences between years and you don't need to do anything special. Your wiring harness and IDM will hook right up.
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #3 of 5 Old 10-13-2013, 11:36 AM Thread Starter
shoopie's Avatar
both my 96 and 97 heads have 10 bolts on the plenums. its getting 3"ers anyway with a t4 mount, intercooler and efuel
1996 RCLB 7.3L auto
East Hampton, NY
shoopie is offline
post #4 of 5 Old 10-13-2013, 11:47 AM
CSIPSD's Avatar
Should swap right over assuming its an OBS to OBS swap...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 5 Old 10-13-2013, 12:04 PM Thread Starter
shoopie's Avatar
yea its obs to obs i just noticed some of the sensor plugs are different i.e. the oil temp sensor on the hpo rez on the 96 has a rectangular plug where the 97 has a round plug. wondering what else is different. thats just as simple as swapping the sensors though correct?
1996 RCLB 7.3L auto
East Hampton, NY
shoopie is offline
