Cummins Guy helping Stroker - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-13-2013, 08:47 AM Thread Starter
Hey guys im a Cummins guy, but my friend just asked me what i can do to give him more power for his stroker. Im not to familiar with the performance and drivetrain on the Strokers.
He has an auto E40D tranny. Completely bone stock. I know my dodge had to have built tranny because they suck. In order for him to get a good kick in power what do you guys suggest. I told him build the tranny (unless they arent like a dodge) a tuner (SuperChip, TS, HyerTech), and gauges. Then if he wants later on a set of injectors and a turbo upgrade. What do you all recommend would be a good mild setup for him?
Im a member on cumminsforum and know all about the stickies. I appreciate if you dont ride me about this. Thanks in advance
99coalroller24V is offline
post #2 of 6 Old 10-13-2013, 08:50 AM
Powerstroke_21's Avatar
i just did and exhaust and ts 6 pos tuner with custom tunes and just those two alone really woke my 99' up
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #3 of 6 Old 10-13-2013, 08:56 AM Thread Starter
Hes got a 5" so thats good. His is a '97. On these trucks is that mechanical or electrical for that year?
post #4 of 6 Old 10-13-2013, 09:14 AM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
pretty sure to was mechanical , set of gauges , new exhaust system , tymar 6637 intake to get more air flowing and a set of Tony Wildman tunes or DP or TS...those are the basics untill you move into injectors and turbos , althought im pretty sure he will need to beef up the E40D ounce he moves into injectors and turbos
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #5 of 6 Old 10-13-2013, 09:35 AM
Quoted: 53 Post(s)
Mechanical or electrical what?
The Powerstroke is a HEUI engine - Hydraulically-powered Electronically-controlled Unit Injector. Engine control is completely electronic; the accelerator is drive-by-wire. The fuel pump itself is mechanical.
madpogue is offline
post #6 of 6 Old 10-13-2013, 02:45 PM Thread Starter
Yea the pump and like an ECM. Like a Cummins the 12 valves were all mechanical then 24 valves like i have are electrical pumps, sensors, and the whole shabang.
