A/C Compressor Clutch Wont Engage - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-12-2013, 12:33 PM Thread Starter
What should I check next?
I Fixed the clutch gap at the compressor. measures at .022".
But the clutch doesnt engage. No voltage at the clutch switch or the high pressure switch.
If I jump the low pressure switch, the clutch comes on. OK.. Bad LPS. Installed a new LPS, and the clutch still only comes on with a jumper on the LPS side.
What do I check now to get my A/C Working again?
williameub is offline
post #2 of 7 Old 10-12-2013, 12:48 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
How much Freon is in the system
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 7 Old 10-12-2013, 12:50 PM Thread Starter
I dont know. Not a whole lot. Im guessing theres not enough freon to trip the switch?
post #4 of 7 Old 10-12-2013, 05:08 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Correct. Put some in until the compressor kicks on.
dirtcrew51m is offline
post #5 of 7 Old 10-12-2013, 06:48 PM
Quoted: 3 Post(s)
You can get the can that has a gauge on it. Check it and if it needs some put some in, if it needs some check for a leak
post #6 of 7 Old 10-12-2013, 06:50 PM Thread Starter
Alrighty, How would one go about checking for a leak?
post #7 of 7 Old 10-12-2013, 07:50 PM
Quoted: 3 Post(s)
Freon is a fluorescent green if the leak is big enough it will be obvious so look look for that color. Most parts stores sell a light to aid in finding a leak, worst case scenario you take it to a shop to have them find it
