Coolant leak? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-11-2013, 04:49 PM Thread Starter
Pwnm30rdi3's Avatar
Coolant leak?
I just dropped this freshly rebuild motor into my truck a month ago. I've put about 2500 miles on the new engine. For the first 1500-1750 I was leak free. Now I seem to have a coolant leak. It looks like it is coming out where the oil cooler meets the block at the front of the motor. I rebuilt the cooler and the cooler itself doesn't seem to be leaking. I double checked the 2 bolts holding the cooler to the block and they are TIGHT...
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 9 Old 10-12-2013, 06:08 AM Thread Starter
Pwnm30rdi3's Avatar
Anyone have any ideas? :/
1997 F350
post #3 of 9 Old 10-12-2013, 07:02 AM Thread Starter
Pwnm30rdi3's Avatar
Coolant only leaks when motor is warm and is off. Checked the Tstat housing and it is dry as a bone.
It doesn't look like a bad oil cooler o-ring but it's hard to see up in there.
1997 F350
post #4 of 9 Old 10-12-2013, 08:38 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Clean the area look from the top to see if any coolant is leaking above where you're seeing the leak. I'd also use a pressure tester as well and check in front of the leak incase the fan was blowing the leak backwards
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #5 of 9 Old 10-12-2013, 12:27 PM Thread Starter
Pwnm30rdi3's Avatar
Did some more investigating. The leak is in fact coming from where the oil cooler meets the block.
If I wipe off the oil cooler neck where the coolant is collecting (with engine off), coolant appears seconds later. I hope I didn't crack anything. Any tips on removing this bad boy?
When I rebuilt the oil cooler, it was out of the truck.
1997 F350
post #6 of 9 Old 10-12-2013, 07:42 PM Thread Starter
Pwnm30rdi3's Avatar
I believe I found my culprit. I pulled everything apart and made a huge mess. After I got everything cleaned off I couldn't find anything that may have caused my leak. Then I took a closer look at my gasket and found this!
1997 F350
post #7 of 9 Old 10-12-2013, 08:00 PM
Quoted: 3 Post(s)
That sucks are you planning on changing the oil after everything is back together?
post #8 of 9 Old 10-12-2013, 08:39 PM Thread Starter
Pwnm30rdi3's Avatar
Yeah! I'm almost at my 3000 mile oil change marker anyways
1997 F350
post #9 of 9 Old 10-13-2013, 10:14 AM Thread Starter
Pwnm30rdi3's Avatar
Finished putting everything back together today.
Bought more coolant... Again
and did my oil change!
Made a huge mess in my driveway, but my leak is fixed and the truck is up and running again! Yay!
1997 F350
