Alarm system question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-11-2013, 04:04 PM Thread Starter
95Hailey7.3's Avatar
Quoted: 4 Post(s)
Hello everyone,
I did a search on alarm systems and got a couple different things that pertained to what I was looking for. Although some hit topics that drew my attention but not what I was looking for. I have an alarm system on my truck, not sure if its factory or not. I guessing it's not since I have a Centurion conversion. The alarm worked great when I bought the truck, the problem arose when I was replacing the dual flywheel with a single. I took the starter off thinking it need to come off in order to get the transmission off. I had totally forgot that I didn't unhook the battery. The positive wire to the started touched the underside of the truck. None of my fuses blew but when I got everything back together I did notice my truck alarm would randomly go off when armed. I had to pull a fuse that creates a break in the circuit but also prevents me from starting my truck with out it in. I did some tracking down and found this box zipped tied under my dash. I took some photos of my setup.
1972 Ford F100 5.9L FE Sport Custom Single Cab Long Bed 4x4 6" Rancho lift kit, 16x10 Pacer rims wrapped in Durango 315 75 R16.
1995 Ford F-250 XLT 7.3L PSD Super Cab Long Bed, everything stock, rims wrapped in Rocky Mountain Faulkens.
1994 Ford F-350 XLT 7.3L PSD Centurion Super Crew Cab Long Bed dual rear wheel, Alcoa Rims wrapped in Transforce H/T & Big Foot A/T
Young Gun, Proudly Serving So My Family and Friends can LIVE IN FREEDOM.
95Hailey7.3 is offline
post #2 of 8 Old 10-11-2013, 04:08 PM Thread Starter
Quoted: 4 Post(s)
I found this box under my dash and decided to pull it apart, what I found inside was what I believe the problem.
post #3 of 8 Old 10-11-2013, 04:20 PM Thread Starter
Quoted: 4 Post(s)
My question is
What is the thing that is circled in red?
What is the yellow thing below it that is circled in blue.
I did notice when I armed the system and moved the plastic zig zag thing away from the yellow piece the alarm would go off.
If anyone can help me explaining how it works I would like to have my alarm back and my remote entry please.
post #4 of 8 Old 10-12-2013, 04:59 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
That is a dealer installed item and approved by Ford to be on there. A dealer ought to be able to help
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #5 of 8 Old 10-12-2013, 06:48 AM
Quoted: 83 Post(s)
Feedback Score: 4 reviews
That is the shock sensor and the piece with the knob sets the sensitivity. I think I have a couple of extras in the shop.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #6 of 8 Old 10-12-2013, 03:09 PM Thread Starter
Quoted: 4 Post(s)
I have turned the knob both ways and the alarm still goes off randomly. It only started after the positive wire touched the underside.
If you had an extra would it be a simple wire up and or if the plug the same hook up and operate. Or is there going to be a problem with the key fob and the brain system?
post #7 of 8 Old 10-12-2013, 04:51 PM
Quoted: 83 Post(s)
It should plug right in. I"m pretty sure that you can unplug it and everything else will still work, you just won't have the shock sensor feature.
Jack
322000 miles
post #8 of 8 Old 10-20-2013, 04:27 PM
My truck had the dealer alarm too. I didn't know it had it til I disconnected the battery to switch out the starter and it wouldn't start. My mechanic pointed it out to me and showed me how to reset it. It also messed with my turn signals. I got pretty tired of that quickly and had a shop take it out and wire it back to original. 2 hours labor...problem solved
-Austin
1996 F-250 XLT ECLB 4x4 w/E4OD 119k and counting
6637 intake
Diamond Eye 4" turbo-back exhaust
rebuilt tranny
1998 Buick Regal GS 149k
parts runner with blown head gasket
acprimus631C is offline
