Blinker and hazard issue - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-11-2013, 02:42 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Well my blinkers act like there is a bulb burnt out on both sides. They flash way too fast and my hazards do the same thing. I dont have any burnt out bulbs, i replaced the turn signal CB with a known good one. I thought maybe my TBC was messing with it since its plugged in to the factory plug but nothing. Any ideas for me? Thanks
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #2 of 13 Old 10-11-2013, 03:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Fuses? Led bulbs?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 10-11-2013, 03:31 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
No led bulbs on my truck. I cant see it being a fuse since they work just not correctly
tony
1997 F250 4.10's
south bend clutch
post #4 of 13 Old 10-11-2013, 03:40 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Wire short to ground will hyper-flash the system too. With the hazards/turn switch activated are any of the bulbs brighter or darker than the others? The fuse is bigger than the flasher unit so the flasher unit will cycle before the fuse burns.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 13 Old 10-11-2013, 05:20 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
All the bulbs seem to be fine, none brighter than others.Any common places to look for a short?
tony
1997 F250 4.10's
south bend clutch
post #6 of 13 Old 10-11-2013, 05:40 PM
95Hailey7.3's Avatar
Quoted: 4 Post(s)
Could you have bought a flasher with more flashes per min? I grabbed one that flashed more per min, so my flashers and hazards flash at different speeds.
By the way, hope this doesn't come off as I'm insulting your intelligence. More asking if a common mistake of grabbing a part in trying to get the problem fixed quick.
1972 Ford F100 5.9L FE Sport Custom Single Cab Long Bed 4x4 6" Rancho lift kit, 16x10 Pacer rims wrapped in Durango 315 75 R16.
1995 Ford F-250 XLT 7.3L PSD Super Cab Long Bed, everything stock, rims wrapped in Rocky Mountain Faulkens.
1994 Ford F-350 XLT 7.3L PSD Centurion Super Crew Cab Long Bed dual rear wheel, Alcoa Rims wrapped in Transforce H/T & Big Foot A/T
Young Gun, Proudly Serving So My Family and Friends can LIVE IN FREEDOM.
95Hailey7.3 is offline
post #7 of 13 Old 10-11-2013, 06:37 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
I catch mine around the drivers battery area or where the wiring bends up to the bulb at the rear of the bed. Check your pigtail for loose wires and nothing that would carry a current in the 7-way pin area.
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 13 Old 10-11-2013, 07:35 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
No i took the one from my D60 donor and it works fine in there along with my original one. No offense taken dont worry
Thanks ill check that in the morning. Hopefully i can get this figured out
tony
1997 F250 4.10's
south bend clutch
post #9 of 13 Old 10-12-2013, 05:42 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
If you can't find it make em flash faster like strobes
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #10 of 13 Old 10-12-2013, 08:30 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Causing seizures on the highway.
Matt
'97
-Stage II trans.
BigFuel is offline
