Underhood light? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-11-2013, 11:37 AM Thread Starter
KS_
Quoted: 22 Post(s)
Underhood light?
I have a somewhat newer hood I have from the junkyard, it came with a light under the hood and a connector. I've looked and looked and can't seem to find where this connects. Anyone have any idea where it connects?
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 13 Old 10-11-2013, 11:45 AM
Term3's Avatar
Wiring harnesses can be different from model level to model level. For example, my Excursion had the optional tube style running boards but I bought some regular lighted running boards off a guy that had the same year of Excursion as I did but there was no harness plug on my Excursion for them to connect to.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 13 Old 10-11-2013, 11:49 AM Thread Starter
KS_
Quoted: 22 Post(s)
That would just be a shame.. this light would come in handy. I just don't know how I would even start to go about running it to where it would work without a harness. Idk if it works off sensing when the hood is open or what
KS_ is offline
post #4 of 13 Old 10-11-2013, 12:18 PM
Arcturus's Avatar
I have one and never even thought how it goes on and off. There is no visible switch. It comes on and off right about 10* above level. Maybe a mercury type switch?
Not sure of this any help to you but here ya go anyway.
[IMG][/IMG]
It is tapped into the wiring bundle that runs right below
[IMG][/IMG]
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #5 of 13 Old 10-11-2013, 12:27 PM
Term3's Avatar
The ones I've seen had a mercury switch.
Term3 is offline
post #6 of 13 Old 10-11-2013, 12:35 PM Thread Starter
KS_
Quoted: 22 Post(s)
Yeah I'm sol lol, I would try running the wires straight into the bundle but its not worth it to screw something up. I was just seeing if I needed a new glowplug relay when I seen the cord dangling from under my hood.
KS_ is offline
post #7 of 13 Old 10-11-2013, 12:36 PM Thread Starter
KS_
Quoted: 22 Post(s)
KS_ is offline
post #8 of 13 Old 10-11-2013, 12:51 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just run a wire from the light to the battery with an inline fuse. The light comes on when the hood is lifted past a certain angle. Or you could run it from the fuse block for a cleaner look.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 13 Old 10-11-2013, 01:10 PM Thread Starter
KS_
Quoted: 22 Post(s)
I don't need to worry about that black wire that I'm guessing is a ground? Or do I need to ground it
KS_ is offline
post #10 of 13 Old 10-11-2013, 01:11 PM
Quoted: 8 Post(s)
You need to ground it also.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
