engine compartment detail??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-11-2013, 09:33 AM Thread Starter
Howsa7.3's Avatar
hey guys any good recommendations on spiffin up under the hood?
Howsa7.3 is offline
post #2 of 8 Old 10-11-2013, 10:24 AM
Arcturus's Avatar
There are even colored radiator hose that Mishimoto sells for example, here in red.
Mishimoto Radiator Hose Kit Red Silicone 94 97 Ford F 250 V8 7 3L Powerstroke | eBay
Intercooler is pretty spiffy. Change you intake boots to similar color.
Cxracing 94 97 Ford F250 F350 Super Duty Powerstroke Diesel 7 3L Intercooler Kit | eBay
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 8 Old 10-11-2013, 10:53 AM Thread Starter
Howsa7.3's Avatar
I meant more like cleaning and degreasing
Howsa7.3 is offline
post #4 of 8 Old 10-11-2013, 11:30 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
A warm engine(not hot), spray down with purple power and keep it wet for 10 min with purple power(stay away from the alt) then hose it off. You will be amazed with the difference
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 8 Old 10-11-2013, 11:45 AM
Arcturus's Avatar
Doh!!!
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #6 of 8 Old 10-11-2013, 12:20 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Originally Posted by Arcturus View Post
Doh!!!
Shoulda had a V8
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 8 Old 10-11-2013, 01:11 PM
Phillipjon's Avatar
Quoted: 78 Post(s)
I would bag the air filter.
Phillipjon is offline
post #8 of 8 Old 10-11-2013, 01:15 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I use simple green and a pressure washer. Just don't directly spray the alternator and you'll be good. If your air filter is exposed I'd cover it. One guy on here stated tat after he did this he smelled the simple green thru his heater but I haven't experienced this yet and I've done it for years.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
