97 OBS F-250 Dome Lighting - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-11-2013, 08:56 AM Thread Starter
What size light bulbs go in the dome light for the 97 F-250? The person I bought it from had LED bulbs in there that do not work. I am wanting to go back to the original. Thanks for the help with the size.
tucker0104 is offline
post #2 of 6 Old 10-11-2013, 09:00 AM
Quoted: 53 Post(s)
Try turning the blub around.
madpogue is offline
post #3 of 6 Old 10-11-2013, 09:09 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Led only work in 1 direction, flip it around I bet it works
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 10-11-2013, 09:12 AM Thread Starter
I did it and it didn't work. There is an LED in the center one that works great but the two side one's with the on/off switch not so much. Please help with the bulb size.
post #5 of 6 Old 10-11-2013, 09:36 AM
Quoted: 53 Post(s)
Ah, those are the map lights. Dunno if you've ever owned a Ford of this era before, but the original tungsten bulbs in those lights make the housing EFFING hot. Like, touch the metal while fumbling for the switch and almost burn your fingertip, kinda hot. They're actually a perfect candidate for LEDs, for that reason. I would look for another brand of LED, and also double-check that the sockets are actually getting energized. Bulb number is 105 according to RockAuto, but confirm with the owner's manual.
madpogue is offline
post #6 of 6 Old 10-11-2013, 10:32 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The 96-97 have a black plastic housing, the 92-95 have the chrome metal housing
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
