Squeaking noise - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-10-2013, 06:17 AM Thread Starter
Halby95's Avatar
Squeaking noise
Hi ive got this squeaking noise whenever im going around 25-30 mph and i let off the pedal and coast. It happens at lower speeds too. I cant figure out what it is. I changed the u joints and its still doing it so im kind of stumped. Thanks for any help.
1996 F250
Reg. Cab
5 inch exhaust
Afe Proguard 7 intake
Tony Wildman chip
4 inch lift with 295/70R18 Trail Grapplers
Vortex Bedliner on rockers
Halby95 is offline
post #2 of 8 Old 10-10-2013, 06:33 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Does it happen when you hit bumps in the road? Check your bushings in the springs, cab mounts, and your belt
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 10-10-2013, 07:34 AM Thread Starter
Halby95's Avatar
It seems to do it no matter what the road surface is like it still squeaks. Yea i will check them. Is there any way to check them to see if they are good or bad without removing them?
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #4 of 8 Old 10-10-2013, 08:41 AM
I had a nasty clunk in my old F350 gasser, that would show up at the strangest times. One day I went to do some service and when I hoisted myself up on the left fender, I heard the "clunk"
I discovered the source to be the body bolts that hold the fenders to the cab...once I tightened them all, the clunk vanished for good.
You might be chasing the same kind of ghost...
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #5 of 8 Old 10-10-2013, 11:46 AM
Quoted: 50 Post(s)
^^^^^ Seems like loose fender bolts (near the hinges) are very frequently misdiagnosed as suspension/steering/driveline noise.
Automatic or manual transmission? How long does it last after it starts?
madpogue is offline
post #6 of 8 Old 10-10-2013, 12:12 PM Thread Starter
Halby95's Avatar
I dont know if you are asking me or him but mine is a manual and it does it pretty much whenever.
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #7 of 8 Old 10-10-2013, 01:25 PM
Quoted: 50 Post(s)
Not sure what "pretty much whenever" means. Does that mean it keeps squeaking until you stop, or until you acclerate again?
madpogue is offline
post #8 of 8 Old 10-10-2013, 05:06 PM Thread Starter
Halby95's Avatar
Im thinking its my one of my brakes sticking. Sorry that wasnt a very clear way of saying it. What i meant was it makes the noise at about 5-10 mph and 35-40 mph but it makes the noise if your on any road surface rough or smooth. I think its the brakes because if i tap the brakes it stops for a sec and then starts again once i let off. Thanks for all of yalls help i apreciate it.
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
