Front axle brackets - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-06-2008, 07:04 PM Thread Starter
Front axle brackets
So was going to install my 4 inch lift today when we ran into a problem trying to remove the bolts that hold the axle housing to the brackets that attach to the cross member.
I have two questions..
1. The bolts would not move, and I have a large shop compressor and a very powerful impact. Are these bolts held with loctite that requires heat to break the bond?
2. The brackets from the cross member to the axle housing, how are they attached at the cross member? Are the vertical bolts actually studs? If not how do you remove the bolts without lifting the engine? Or get a wrench on them? I am really hoping they are studs...
Steve
1996 F250 XLT PSD 4X4 SuperCab Long Box 5 speed with SMF, aFe intake, 4" lift, edge evolution tuner, stereo, gauges, 38.5/13/16 boggers(mud), 285/75/16 procomp xtreme ATs (street), dana 60 swap, lights, airbags, canopy, etc, etc
silentnine is offline
post #2 of 3 Old 07-06-2008, 07:10 PM
Rice Hunter
Diesel Freak's Avatar
Not sure about your OBS but I'll guess you'll be needing a "GAS AXE"
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #3 of 3 Old 07-06-2008, 07:33 PM
Big K's Avatar
Yes, Heat
Not studs, they are just bolts
You have to get a MID length wrench up there, I can't remember the size... Let me look it up, I know I had to BUY one
Kevin "Big K" Neal
President
North Texas Power Stroke Association
972-768-7252
Big K is offline
