Pull the cab or pull the engine - Ford Powerstroke Diesel Forum
post #1 of 32 Old 10-07-2013, 06:12 AM Thread Starter
Spud Monkey's Avatar
Broke two bolts going from the turbo housing to exhaust collector y pipe and I would just take the two pipes feeding from exhaust manifold to it off but, PO genius thought it be best to weld the coupling to it. So should I just pull the cab to repair all this or pull the engine. I also am trying to get the pedestal off to delete the EBPV and putting a diamond eye turbo back exhaust on it. It's single cab flatbed truck with ZF5
Spud Monkey is offline
post #2 of 32 Old 10-07-2013, 06:30 AM
broncomitch's Avatar
Pull motor.
It's pretty painless
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #3 of 32 Old 10-07-2013, 06:31 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You can't just un bolt the up pipes outta there and pull the y and the up pipes at the same time?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 32 Old 10-07-2013, 07:46 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i'm with kris on this one. and if need be cut the the up pipes used ones can be picked up really cheap
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 32 Old 10-07-2013, 08:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Nobody else seeing this??????
Spud, how did you get the turbo off the pedestal with studs still in the exhaust collector and the pedestal still in the truck????????????
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 32 Old 10-07-2013, 08:50 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Ohh I saw it, just figured he put it back in
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 32 Old 10-07-2013, 09:02 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Originally Posted by Spud Monkey View Post
.....or pull the engine. I also am trying to get the pedestal off to delete the EBPV and putting a diamond eye.....
Doesn't sound like he's gotten that far yet.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #8 of 32 Old 10-07-2013, 09:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How in the world
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 32 Old 10-07-2013, 09:25 AM Thread Starter
Easy just unbolted the four bolts under the pedestal to turbo off take the down pipe off took the lift pump out pulled the fuel canister too and took the 4 bolts off the exhaust collector. Did I do what most consider impossible cause the four bolts on the exhaust collector?
post #10 of 32 Old 10-07-2013, 09:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Me tooooo, WTF
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
