Trying to do the ball joints on my 95... - Ford Powerstroke Diesel Forum
Old 07-03-2008, 05:40 PM
...but all the tutorials i have found are for the 98 and newer trucks. I did the ball joints on my friends 2000 f350 4x4, and the tutorial was great, but my 95 f250 4x4 has a different axle. It seems mostly the same, is there anything i should know that will be different about the job before i start?
Also, none of the dealerships stock any hub o-rings or seals. How necessary is it that I replace them with new ones? I have time off work this Saturday, and i need the truck for construction next week, so I am pressed for time.
Thanks for your help!
Old 07-03-2008, 05:59 PM
It all comes apart the same, the only difference is the wheel bearings. The greese seals should be avalible at your local auto parts store.If youve done a newer one you can do this one.
Old 07-03-2008, 06:44 PM
Shade tree mechanic
just did mine, pretty self explanatory once you get into it
Old 07-03-2008, 07:08 PM
ADMIN AND TECH
ill second that
Old 07-03-2008, 09:30 PM
Great, thanks for the words of encouragement. I will pick up the hub grease seals and carry on.
