Windlet Handle Broke, How do I fix it? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-06-2013, 10:40 PM Thread Starter
Pwnm30rdi3's Avatar
I went to open my passenger side windlet and the handle broke off. I have no idea how to go about fixing this... Do I need to replace the entire window?
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 7 Old 10-07-2013, 08:56 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
you can get just the handle. on lots of trucks over the years and as far as i know they are all interchangeable.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 7 Old 10-07-2013, 05:44 PM Thread Starter
Pwnm30rdi3's Avatar
I was able to find the handle on LMC for $10
I needed to order a few window seals from them anyways! Hopefully I can figure out how to remove the broken old one and replace it with the new one!
1997 F350
post #4 of 7 Old 10-12-2013, 12:27 PM
Post up how you did the repair. I just broke my drivers side one last. Be good to have tips on how it's done. Thanks Jeep
97 F250 2WD Extended Cab Long Bed XLT. 234K Miles and going strong. 3" downpipe, 6637 Air Filter,10K mod. Cat sleeps with fishes. Modded turbo base to make it easy to RnR banjo bolt. Shimmed fuel pressure regulator.
Jeep1947 is offline
post #5 of 7 Old 10-17-2013, 05:40 PM Thread Starter
Pwnm30rdi3's Avatar
Turns out the entire corner window needs to be replaced, frame and all.
The frame and glass ran about $110 with shipping.
I'll post up pictures when I figure out how to get this new window in!
1997 F350
post #6 of 7 Old 10-17-2013, 05:51 PM
Quoted: 43 Post(s)
So why do they sell just the handle? Or was it part of the frame that broke in your case?
madpogue is offline
post #7 of 7 Old 10-17-2013, 06:02 PM Thread Starter
Pwnm30rdi3's Avatar
According to my glass guy, there is a tab that is attached to the window frame. That tab is usually what breaks off. In which case, the entire frame must be replaced.
I think that they sell the handles for people restoring their interiors.. My old handles were very sun faded.
1997 F350
