ARCHOIL on most recent oil change. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-06-2013, 07:52 PM Thread Starter
Just did a Rotella T6 5W-40 oil change today...even going so far as to change the HPOP oil as well. I would be adding a dose of ARCHOIL as per their directions and I wanted to make sure I got as much of the old stuff out as possible.
HPOP holds about 800 ml of oil, so I added a tablespoonful of the additive to that reservoir, then drained the sump...new filter...new oil and the full 12 oz of ARCHOIL.
I've put a dozen or so miles on it so far and to tell you the truth...I haven't noticed anything amazing or noteworthy. The engine isn't any quieter than before...starts the same as always...too early to judge mileage.
But...being an easy mark for a product with the sorts of claims it makes...I'll be watching closely. I'm hoping that there is SOME truth!
I ordered a 7.3 PSD Package that came with the friction modifier and fuel additive.
Anybody else use the stuff? What is your opinion on it? Worth it?
BTW...mine is a 97 with just over 112,000 miles...so maybe I don't have enough wear and tear for it to be noticeable!
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 8 Old 10-07-2013, 02:46 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Another elixir. Might work in the newer tight tolerance motors. You will not notice the difference on our motors, if anything best to use Lucas, it stays tacky and helps keep the oil stable with the heat generated to keep the parts protected. There is nothing you could use in the oil or fuel to add mileage and power as advertised, its like the idiots on ebay selling chips that give you 100hp and 20+ mpg.
dirtcrew51m is offline
post #3 of 8 Old 11-08-2013, 07:42 PM Thread Starter
Just over a month with this stuff and I can honestly say that I don't notice any difference from before.
As I said; I'm an easy mark for anything that implies it will save my engine...but it has to make SOME kind of difference.
Might get ONE more treatment for the next oil change (since it will be Spring and I'll be switching back to dino-oil)...but unless I see improvements while hauling the RV, it will be the last time.
Qwazert is offline
post #4 of 8 Old 11-08-2013, 11:47 PM
Rodslinger's B1TCH
changing to rotella t6 made a huge difference in cold starts on mine... warm starts are a little quicker too.
there's no reason for anything else to change much. diesels make the sound they make because they need to. if it starts to run quieter than normal, you probably have a problem.
steve604 is offline
post #5 of 8 Old 11-23-2013, 07:12 PM
Snake Oil only does one thing, it drains your wallet. A good quality oil should not need any type of additive to make it better. Some additives are also harmful and can change the chemistry of the oil. Bottom line is don't waste your money on them.
JTWAT is offline
post #6 of 8 Old 11-24-2013, 04:13 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Get rid of the t6 and use schafers oil, mobile1, AMSOIL, or even Delo. A lot of bad oil tests on t6 and after running some of the oils listed above the truck runs better, starts better , idles smoother ect.... I will never run t6 again
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #7 of 8 Old 11-24-2013, 05:13 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
Can you post the links to the tests for the t6? Itd be interested to see what these tests say. I ran t6 for 40k miles that I had my 6.4 and did Blackstone oil report for every single oil change and had nothing but great things with the t6.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #8 of 8 Old 11-25-2013, 08:56 AM
ol_Blue97's Avatar
I don't have links or the paper work that I had done but common rail vs a 7.3/6.0 can have very different results. I had signs of copper and ???? I forget the other which showed signs of bearing wear. Changed oils and did a test again after 2 oil changes and it was perfect
The reason I can't provide a link is because it was in the abyss of a chat thread. But there were others that had the same issue which prompted me to run a test
FRANK THE TANK
