97 F250 PCM - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-05-2013, 08:35 AM Thread Starter
97 F250 PCM
My truck just shut off while towing a trailer. Local mechanic tried to pull the codes but PCM wouldn't communicate with the ICM. PCM is dead. Where can I either purchase a reman, or have mine repaired? thanks
tr97psd is offline
post #2 of 15 Old 10-05-2013, 09:56 AM
kraker829's Avatar
Have you checked all the fuses? Not just looking at them actually test them with a test light or power probe?
sent from a hand held computer that I don't know how to use.
kraker829 is offline
post #3 of 15 Old 10-05-2013, 10:50 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Manual or auto? I have both
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 15 Old 10-05-2013, 12:57 PM Thread Starter
Kraker829, I did check all fuses with a test light.
351fifty, manual.
tr97psd is offline
post #5 of 15 Old 10-05-2013, 01:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I have a 94.5 manual pcm
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 15 Old 10-05-2013, 03:31 PM Thread Starter
I'm not sure what year models interchange. I was told the number on my PCM would need to be the same on any replacement. But I'm not sure if this is correct.We tried a PCM out of a 96 but for whatever reason it only connected partially with the ICM. The number is F7TF - 12A650-PE. the only other number shown is JKA4. Also told that a different PCM would require being programmed to my truck. Not saying this information is correct, just what information was passed on to me..
tr97psd is offline
post #7 of 15 Old 10-05-2013, 03:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
94.5-97 all work unless you have a Cali model
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 15 Old 10-05-2013, 04:22 PM Thread Starter
I appreciate your offer, unfortunately mine is a Cali truck. Thanks for getting back to me.
tr97psd is offline
post #9 of 15 Old 10-05-2013, 05:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That's rough bro, good luck unless you wanna swap to a federal PCM
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 15 Old 10-06-2013, 07:52 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Too bad it's a Cali 97. The PCM's are completely different due to the GPR monitoring circuit (pins and functions have been moved around) and the programming for the splitshot injectors. You would have to have another DPC-311 series PCM with a JKA_ program. I've never really looked at taking a DPC-203 with a AUG_ code (from a Cali 96 with splits I think ... someone veriify or deny that) or reprogramming it to one of those codes and repining your harness for it. Those of us have looked into it for the automatic 97 Cali's since the PCMs are very hard to find. Cheers!
Patrick Feeley is offline
