New truck question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-04-2013, 07:46 PM Thread Starter
New truck question
Hi all, Im going to pick up my new 98 f350 in two weeks and Im curious about the pre-99 diesel thing. This truck shows 11/98 on the vin sticker so what's the difference between a 98 7.3 and a 99 7.3? Im looking at some minor upgrades(intake/exhaust/chip) in the future. Will this hinder the performance if its an earlier 7.3? Thanks for your help on my first post!
scottrepos is offline
post #2 of 7 Old 10-04-2013, 08:30 PM
PhilMac's Avatar
It should be considered a 99 then. If i remember correctly anything built in August or later is the following year. I don't believe there are any differeneces in the 98 to 99. Biggest difference being a super duty and having a intercooler. It will respond well to an intake, exhaust and chip. if you get carried away with power be mindful the trans/clutch.
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
PhilMac is offline
post #3 of 7 Old 10-04-2013, 08:42 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Yup! It's an early 99... Miss my old one. They are a half bread between the 97 and late 99-2000 trucks. Best reason to buy it is you are guaranteed to have forged rods... But the HPOP is smaller (15*) So early 99 don't respond as well to stage 1-2 injectors. There is a thread all about the difference between the two (early and late 99's). I'll try and dig it up for ya. Oh, and
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 7 Old 10-04-2013, 08:44 PM
Quoted: 8 Post(s)
Very first link using google... Haha got love seeing powerstroke.org at the top!
Early 99 vs Late 99
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 7 Old 10-05-2013, 03:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The turbo, hpop, injectors, PCM, intake spider, up pipes, and a couple other minor things, all which can be swapped easily tho with the later stuff
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 7 Old 10-05-2013, 04:42 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
You can swap all that stuff on an OBS too, but I wouldn't call it "easy"
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #7 of 7 Old 10-05-2013, 05:06 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
On an sd it's a little different but I've heard if you swap the e99 PCM to a later model one the cruise control light actually works
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
