Fuel has been sitting in 2nd tank...ok to use? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-04-2013, 08:52 AM Thread Starter
Ever since I've owned the truck, I've been using the front tank regularly with the rear tank as a backup. Currently the rear tank is about 1/2 full. I filled it the first time I fueled the truck a few months ago and haven't touched it since. I doing a small road trip tomorrow and was thinking to use the rear tank to empty some of the fuel. Is this a good idea given that the fuel has been sitting in the tank for a few months?
DChalue413 is offline
post #2 of 3 Old 10-04-2013, 08:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Add some treatment to it and run it, or top it off with fresh fuel, since you have been driving it it is still being moved around in there
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 10-04-2013, 12:23 PM
Arcturus's Avatar
Power Service Diesel Kleen if available. I switch tanks at every fill. One tank is always full except on long trips.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
