Remove Oil from Single Injector Hole - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-03-2013, 04:38 PM Thread Starter
ArXane's Avatar
Most of the directions about injector R&R talk about starting with the far back cylinder for the oil to train into. When just doing 1 injector whats the right way to do it? I will be putting in a new injector on cylinder #3, I removed the two oil rail drain plugs under the cylinder (stripped them both, anybody got a part number?) and let the oil drain for about an hour. Then pulled the injector. I know oil/fluid went down. Do I just suck whats out from that cylinder?
2000 F250 Lariat, CC, Long Bed PSD, 4x4, Manual, 102K Miles 4.30 gears, Truspeed
Performance Mods: Tuned by PHP, Wicked Wheel, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: 8" Fabtech all spring lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, 17" ATX Vice, 37" Toyo M/T
1995 RC F350 Longbed 4x4, Manual, 310K miles, Downpipe, cat delete, FPR shim. (Farm Truck)
ArXane is offline
post #2 of 4 Old 10-03-2013, 06:52 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You can just suck the oil out from that cylinder (I use a MightyVac). After sucking it out and installing the injector, I like to leave the glowplug out and rotate the engine by hand a few revolutions using a wrench on the crank bolt just to make sure it won't hydrolock. Here a part number for the plug:
Oil Rail Drain Plug (under valvecover)
(Ford) ???
(International) 1822610C91
Chers!
Patrick Feeley is offline
post #3 of 4 Old 10-03-2013, 08:00 PM Thread Starter
ArXane's Avatar
(Ford) ???
Chers!
Just what I needed. Thanks!
ArXane is offline
post #4 of 4 Old 10-04-2013, 06:04 AM
m j
every plug on these engines are ORB so you might be able to get a plug locally at a hydraulic supply shop
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
