Are these Radiators and turbos the same? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-03-2013, 08:25 AM Thread Starter
cbarm's Avatar
I have a '94.5 F350, one of the early powerstrokes. The rad is completely split between the core and the bottom tank. I called a wrecker and they said that the rads are all the same right from '83 up to '95. Mine has the rad cap on the top of it, and it measures 31" x 23 5/8. Any help would be much appreciated.
The turbo is also leaking oil out the exhaust and Im told that its toast. Is the turbo on all OBS PSD's the same? Would a turbo from a '97 fit on my 94.5?
2010 F450 King Ranch 6.4L 4x4 4.30 ratio 130K miles bone stock
1994.5 F350 XLT 7.3 PSD ZF5 CC DRW 220K miles
cbarm is offline
post #2 of 15 Old 10-03-2013, 08:35 AM
erics diesel's Avatar
I believe the radiator is the same as long as it comes from a diesel truck just be careful if its from a 95 that is the year they switched the style of them. As far ad turbos go any 94.5-97 will work
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 15 Old 10-03-2013, 08:53 AM Thread Starter
cbarm's Avatar
Great!! thanks for the info!!
cbarm is offline
post #4 of 15 Old 10-03-2013, 08:53 AM Thread Starter
cbarm's Avatar
Does it matter if it has A\C or if its an auto or 5 spd?
cbarm is offline
post #5 of 15 Old 10-03-2013, 09:12 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
The rads are different, the 94.5's use an IDI radiator which has a cap on top and the hose routing is different. The turbo is the same as long as its from a 94.5 PSD and not a turbo IDI.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 15 Old 10-03-2013, 09:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I believe the rad support is different if it has a/c on those trucks, the rad should be the same between a/c and non ac trucks
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 15 Old 10-03-2013, 09:40 AM
Quoted: 50 Post(s)
The original radiators on 5-speed trucks did not have a tranny fluid cooler in them. With most aftermarket radiators, they don't make different ones for manual vs. auto; they all have the tranny cooler and you simply don't hook it up when you install it in a 5-speed truck.
madpogue is offline
post #8 of 15 Old 10-03-2013, 09:43 AM
Yea 95 is split year, older style big azz radiator or the newer ones, smaller with plastic ends.
Friends truck a 95, pulled old unit out, ok we got a problem.
Napa did have right one in stock.
letitsno is offline
post #9 of 15 Old 10-03-2013, 03:44 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The early powerstokes(94/95) used the same radiator as the 92,93,94 IDI trucks(copper core and tanks). The 91 and older are DIFFERENT
Somewhere in 95 they changed to plastic tanks
As for the turbo, yes all OBS(94-97) powerstrokes use the same Garrett 1.15 turbo
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 15 Old 10-04-2013, 10:19 AM Thread Starter
cbarm's Avatar
I just had a guy call me, he has a '95 7.3 that spun a bearing so he is parting it out. He said to come by n have a look at the turbo n make him an offer. He knows what a new one costs and rebuild kit is worth. What would be a descent price on a used turbo? What do I need to check on it besides the shaft play?
Mine is fried, oil blowing out the exhaust side, and Im wondering if it could be something to do with the pedestal? I am wanting to grab both. What else should I maybe grab off this engine since he is parting it all out?
cbarm is offline
