Should I be Concerned? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-02-2013, 03:34 PM Thread Starter
Had a Powerstroke Certified Technician R&R my fuel filter housing, new hose lines, filter, drain plug, etc. Also replaced the Injector Drive Module, Crankshaft position sensor, and the Exhaust gas recirculator. Ran great for a week.
Went to start it this morning and it idled real rough!. No power. Later in the day I started it again, same thing. Let it chug at idle for a while, then put the pedal to the floor and after a short while the rpms increased big time and it idled smooth. Drove around the block, OK.
I'm guessing that one or more injectors picked up some crud, and now it's flushed through???
Wishful thinking?
How about I add a small shot of VMP Naphtha? (A powerful crud solvent) to the fuel tank.?
Thanks in advance.
Dick
tartansailor is offline
post #2 of 20 Old 10-02-2013, 03:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
So it runs fine when warmed up?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 20 Old 10-02-2013, 04:25 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Wishful thinking?
Thanks in advance.
Dick
NO, do NOT add that to your fuel.
Why was the injector driver module replaced? What was it replaced with?
You also do NOT have a EGR, what exactly did he replace?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 20 Old 10-02-2013, 05:21 PM
PSDTV21's Avatar
Im betting he worked on the oil cooler. Sounds like a great mechanic
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #5 of 20 Old 10-02-2013, 05:38 PM
Quoted: 54 Post(s)
You also don't have a crankshaft position sensor.
madpogue is offline
post #6 of 20 Old 10-02-2013, 06:45 PM Thread Starter
He installed a reman IDM because it would not start.
He also according to the bill, installed a cam sensor, an EBP sensor, and a glow plug relay.
Thanks for asking.
Dick
post #7 of 20 Old 10-02-2013, 06:49 PM Thread Starter
Originally Posted by [B
351fifty;6807921]So it runs fine when warmed up?[/B]
Yes, now, but for how long?
Never had it miss like that before.
Dick
post #8 of 20 Old 10-02-2013, 06:51 PM
Quoted: 4 Post(s)
Is it throwing and codes? How many miles on it?
post #9 of 20 Old 10-02-2013, 06:54 PM Thread Starter
I'm saving up for a code reader, so don't know if any were thrown.
109,650 miles.
Dick
post #10 of 20 Old 10-02-2013, 07:12 PM
Sounds like the GPR if it runs fine when warmed up. Just because they replaced it it doesn't mean that it's working.
Rob73 is offline
