Wiring Question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-02-2013, 09:01 AM Thread Starter
boozinag's Avatar
Wiring Question
My truck has round KC-like lights on the front bumper, wired to a switch in the cab. I bought two small square LED lights to replace them. The LEDs have two Leads, a white and a red and the incandescents have one lead. Each of the leads on the LED is the same size as the Incandescents' small single lead.
How should I wire these in? I have no Idea how to do electrical stuff.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #2 of 4 Old 10-02-2013, 09:33 AM
Quoted: 53 Post(s)
The old lights obviously grounded through the brackets. You have to determine which wire on the LED lights is positive; the documentation that came with the lights should mention that. The positive wire shoud be connected to the power wire (the single wire that went to the old lights) and the negative wire should go to a good ground. If you wire it backward, the LED lights won't light, and you'll have to reverse the wiring.
madpogue is offline
post #3 of 4 Old 10-02-2013, 09:43 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
The one wire on the kc lights is a power wire the ground is accomplished by the bumper through the mount. If you look at the diagram provided with your new lights the white is probably the ground and red is more than likely power. As far as wiring a ground you can wire to a good ground and call it done
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #4 of 4 Old 10-02-2013, 10:36 AM Thread Starter
boozinag's Avatar
Thanks gents, I have fab up a bracket for them, as the tubing prevents mounting. They did not come with any wiring diagrams. I was confused by the lack of a - lead. Should be easy enough then though.
Gerry
184k
boozinag is offline
