Door actuator and lock/ unlock controls - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-01-2013, 03:30 PM Thread Starter
I recon my actuator is on its way out, it's doing that bouncing noise when it opens and closes with the fob. I know there is a thread somewhere around here to mod a resistor so going to give it a shot.
My question is when I'm inside the truck, I can't lock and unlock the doors using the buttons. My windows work fine, both passenger side and driver but doors don't operate (driver and passenger side buttons). I have had to at times either reach over and pull the lever or turn the truck off and use the key fob.
Not too sure if this problem is related to the actuator, sounds more electrical to me like fuse or relay?
I want to peel and seal the doors so need to get this problem sorted first.
As usual, any help or advice is greatly appreciated.
Rob73 is offline
post #2 of 10 Old 10-01-2013, 03:45 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
broken wires going through the door hinge?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 10 Old 10-01-2013, 07:40 PM Thread Starter
I would be surprised if that's the problem Terry. It's happening with the controls on both sides so am more inclined to think its related together, like I said, either a relay or a fuse.
Anyone got electrical diagrams for door panel controls?
Rob73 is offline
post #4 of 10 Old 10-01-2013, 08:18 PM
kraker829's Avatar
I can post them from work tomorrow. Going to try now but my phone and pad don't like the site I use for work.
sent from a hand held computer that I don't know how to use.
kraker829 is offline
post #5 of 10 Old 10-01-2013, 08:29 PM
kraker829's Avatar
Let's see how this turns out.
ID:	176337   Click image for larger version
ID:	176345   Click image for larger version
The Following 2 Users Say Thank You to kraker829 For This Useful Post:
SButler83 (07-01-2016)
post #6 of 10 Old 10-01-2013, 09:04 PM Thread Starter
Thanks Kraker, that's something to keep me going for now. I'm going to rip the passenger door panel off tomorrow and check the supply to the switch. I would be surprised if both switches have stopped working but there is a possibility.
Rob73 is offline
post #7 of 10 Old 10-02-2013, 04:50 AM
the baconator
Quoted: 143 Post(s)
i'm sure you;re right i was thinking it was only happening from the driver's door
post #8 of 10 Old 10-02-2013, 10:52 AM
kraker829's Avatar
Let me know if you need something different. Those were the easiest ones to post.
post #9 of 10 Old 10-02-2013, 05:35 PM Thread Starter
So I decided to have a closer look into the door switch problems today. Pulled the housing out of the door and took out the 3 screws from the back to give access to the 3xbuttons (door and windows). I praised the door switch from its connections and notice that the 5 copper prongs on the back were pretty dirty. I first checked the supply which was giving me 12 volts on both circuits so I knew it wasn't the supply. I then cleaned all the prongs with some wire wool then gave the whole thing a good spray with electrical contact cleaner. Reinstalled and hey presto! After a few cycles of the buttons on both doors, all is good and working again. Another bunch of money saved.
I still need to do the actuator repair but at least for now I can operate my doors from inside.
Thanks to all for the advice and hope my bit of a write up helps someone in the future.
Rob73 is offline
post #10 of 10 Old 07-01-2016, 10:10 AM
SButler83's Avatar
Are those wiring diagrams good for trucks that don't have RKE? If the diagrams are different, could you post those?
Steve in Central CA
'03 F350 CCSB FX4 w/ 7.3L & 4R100, Factory Tech Valve Body, DP Tuner, AIS Intake, & Banks 4" Monster Exhaust 232K MI
'02 F350 SCSB 4x4 OFF Road w/ 7.3 & 6 speed - DP Tuner, AIS Intake, MBRP 4", F650 Dash Mod, AirLift w/ OBA, 223K MI
'97 F350 CCLB 4x4 7.3 & 5spd. 3-3.5" exh, wayne hanson bumper w/ 12k winch, Nelson rear bumper, Gooseneck, 410K
SButler83 is offline
