Fuel Spill While Filling - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-30-2013, 09:40 AM Thread Starter
Hello All,
The first time I tried filling my new to me 1996 7.3 Econoline 350 Van there was a fuel spill under the chassis when the tank was almost full. That was at a gas station selling diesel. (lower flow rate??) Next time at a truck stop (Higher flow rate??) the fuel spilled at 1/2 tank?
The tank does not leak at other times.
What's going on?
Thanks in advance for any help.
Dick
tartansailor is offline
post #2 of 7 Old 09-30-2013, 09:58 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
vent is plugged not allowing air to escape. you will have to drop the tank and clear it.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 7 Old 10-01-2013, 01:11 AM Thread Starter
Nick,
If the vent were plugged it seems to me that the fuel would back up at the fill spout, which it does not.
It's leaking from the top of the tank.
Dick
post #4 of 7 Old 10-01-2013, 03:54 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mite want to drop the tank and find it, probably cracked or loose hose, how much fuel is spilling?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 10-01-2013, 03:32 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Does it leak when the truck is running? Check for cracks in the filler hose, or possibly the lock ring rusted and opened the pickup assembly, also I had a similar problem after I the new tank in, there was a hole in the return line, it leaked when the truck ran, even leaked some when the fuel sloshed around.
dirtcrew51m is offline
post #6 of 7 Old 10-01-2013, 05:54 PM
Doesn't Even Care
Quoted: 69 Post(s)
yeah, might be the lock ring leaking, or a pinched line that started leaking.
Nick
"The Mistress"
post #7 of 7 Old 10-01-2013, 06:03 PM Thread Starter
Sincere thanks everyone.
I just dread dropping that tank.
dick
