cruise control not working
My cruise control isnt working?
Here is what I have check so far, All fuses All brake lights wiring harnesses pressure switch on the end of the master cyclinder. I tried unhooking it and jumping it neither work. Also reverse lights arnt working I dont know if related or not. I did alot of work in the motor and trans and then found these not to be working after. Any way to test anything before just replaceing parts. I already replaced the little plastic peice on the side of the tranny that gos on the shifter arm. |
bump for you
Any idea why the reverse lights aren't working? Also, there is a cruise control sensor (I believe) that had some issues IIRC. Someone smarter than me should be able to help. Scruffy is a genius with these trucks, might PM him.
Craig |
Where's Scuffy, he's the GURU.
Bummmmmmmmmmmmmmpppppppppp! |
I dont know why the reverse lights dont work. Only think I can think is some how its related.
Hey im having the same problem with my 97' No back-up lights and no cruise! I replaced the switch on the master cylinder checked all fuses and even tested the abs sensor on the rear Diff. All is good so whats the Prob?? I even pulled the steering wheel apart and tested the contacts for the cruise buttons and all is good! Hope somebody knows whats going on!
I have changed the peice on the side of the trans with no luck. I think I may swap pcm and try that.
Check for a brokens wire in the steering column
