potentially dumb questions - Ford Powerstroke Diesel Forum
post #1 of 162 Old 09-29-2013, 07:44 PM Thread Starter
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
hello as the title states I have some potentially dumb questions I may for get a few but here are the ones I remember
is there anything wrong with just keeping a 3in exhaust sans cat and muffler after a 3in dp replacement?
besides the sticker on the core support (mine's missing) how can I tell if my truck is a cali model (for the record my truck is a 97 f250 ccsb 4x4 e40d)
what causes the od light to not illuminate when you press the button (fyi my od works but cant take it out)
what is the difference between a 15* and 17* hpop and how do I tell them apart
can I run a high volume or performance hpop on stock injectors and tuning
what are the advantages to reversing the shackle location
can I keep the stock obs front suspension (shackle in front)pivot points with a sd spring
can a 300k engine last if I up the hp to 300-350hp
if I have split injectors are baby swamps injectors reliable to upgrade to
would a winch bumper that has no extra holes in it like the 95-97 front bumpers hurt performance and or cooling
my new toy
thank you for your time
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #2 of 162 Old 09-29-2013, 08:31 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Nothing wrong with it... But then again nothing wrong with letting the engine breathe easier!
check what code the injectors are
Possibly a connection issue or failed button
what is the difference between a 15* and 17* hpop and how do I tell them apart.
The 17* pump flows more oil for the injectors. Allows for higher hp increases when tuned. Not sure on identifying between the two.
yes, some guys see an improvement in performance and milage. Probably because their stock HPOP was getting weak.
your engine will be more than fine, just get gauges and monitor the them along with regular maintenance
stock OBS injectors have AA single shot injectors, I think
it really depends on the design, some guys claim their ECT goes up but upgrading the grille helps a lot. Not sure but maybe you could get a more agressive fan clutch like the 6.0s can have. The 6.0 agressive fan clutch is called a snow plow fan clutch...
my new toy
Read the read. Not sure on all questions
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 162 Old 09-29-2013, 09:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
[COLOR="rgb(46, 139, 87)"]stock is 3.5, but yes it's fine, just find a cat and muffler delete[/COLOR]
[COLOR="rgb(46, 139, 87)"]on the pass side valve cover the is a white sticker with light blue writing saying it conforms to California emissions, PCM code is mme series, a shunt on the glow plug relay, and pop the valve cover to check the code on the injectors, should be "ab"[/COLOR]
[COLOR="rgb(46, 139, 87)"]the light should come on saying its off, but if it's not working then you may need to check wiring/button/fuses[/COLOR]
[COLOR="rgb(46, 139, 87)"]the degree of the swash plate, the 17* version supplies more oil to the injectors[/COLOR]
[COLOR="rgb(46, 139, 87)"]yes[/COLOR]
[COLOR="rgb(46, 139, 87)"]better ride quality[/COLOR]
[COLOR="rgb(46, 139, 87)"]no, the SD spring is longer than the stock obs one[/COLOR]
[COLOR="rgb(46, 139, 87)"]that all depends on tuning, driving habits, and support mods[/COLOR]
[COLOR="rgb(46, 139, 87)"]they aren't big enough IMHO to gain much, just do some160/100's or bigger, but you mite want to look into doing a federal PCM if you have a Cali model[/COLOR]
[COLOR="rgb(46, 139, 87)"]its not going to make a big difference in efficiency or cooling, I ran one for a while, but it limits the ability to install an intercooler pending on which bumper decide to use [/COLOR]
my new toy
That's a nice rig there replies are in green, hope those helped
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 162 Old 09-30-2013, 05:57 AM Thread Starter
Quoted: 3 Post(s)
Thank you for the quick and detailed answers but I now have a few more questions
How many problems would I create / solve by doing a 1 in hockey puck body lift?
How much does a shackle reverse kit lift a truck compared to a stock 1 ton?
Does reverse shackle kit create any pinion angle issues?
Can you use a 1in block on the front end of a ttb to combat camber issues?
post #5 of 162 Old 09-30-2013, 07:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
With a body lift you will have a lot more body roll,
The shackle reversal will only work on a solid front axle, keep this in mind when your wanting to do that, your ttb won't work like that, you can get a lift with a drop carrier shackles for the center as well as the lift springs
I would never in a million years recommend a block lift in the front, never heard of anyone even selling one, but a d60 with f350 springs will give you about 1-2" of lift over stock
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 162 Old 09-30-2013, 09:20 AM Thread Starter
Quoted: 3 Post(s)
I should mention I have a hp60 from a 96 350 that will be going in as soon as I regear it and clean it up so that is where the shackle reversal questions stem from. As far as the lift block idea I concerned I know my springs are weak and worn out and I want to replace them but I can't convince myself to buy springs that will be useless after the swap is done. Long story short I don't want to wear out my tires too fast. In regards to the body lift I was wondering if a 1in body lift would help a 3in dp fit better and maybe give me a little extra room for an eventual zf6 install without having the fan hit the shroud
post #7 of 162 Old 09-30-2013, 11:05 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
My down pipes fit fine with a little persuasion from a long pole between the down pipe that's been cut and the firewall, just get sd springs and use them with an rsk
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 162 Old 09-30-2013, 02:57 PM Thread Starter
Quoted: 3 Post(s)
Where is the best place to install an egt probe
post #9 of 162 Old 09-30-2013, 03:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I've don't the manifold and the intake y flange that goes in the turbo
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 162 Old 10-01-2013, 07:21 AM Thread Starter
Quoted: 3 Post(s)
Are the cali emissions trucks the only ones equipped with a cat?
Is it me or is this thread turning into ask 351fifty questions thread ? It's kinda funny
