Red Brake light on - Ford Powerstroke Diesel Forum
post #1 of 26 Old 09-28-2013, 11:35 AM Thread Starter
Red Brake light on
Red Brake light on and off. It is kicking my cruise off the main issue!
I have replaced the vac pump and also unhooked the wire on the parking brake. Any ides?
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #2 of 26 Old 09-28-2013, 12:44 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
how are the brakes ? spongy feeling? level and condition of brake fluid?
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 26 Old 09-28-2013, 02:09 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
there is a vacuum sensor on the driver side inner fender well. you could have a bad connection
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 26 Old 09-28-2013, 04:41 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Brakes low. Check the front pad thickness.
dirtcrew51m is offline
post #5 of 26 Old 09-28-2013, 05:09 PM
the baconator
Quoted: 146 Post(s)
there are 3 reasons the brake light on the dash comes on
1 the parking brake is on. you've disconnected the wire so it won't ground therefore this is not a problem
2 there is low vacuum at the sensor on the driver side inner fender. the sensor could be bad or cracked or unplugged
3 there is a problem with the master cylinder.
post #6 of 26 Old 09-28-2013, 05:40 PM
m j
4- leaking brake lines have let fluid out and the pressure differential valve is tripping the warning light
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #7 of 26 Old 09-29-2013, 04:19 AM
the baconator
Quoted: 146 Post(s)
and whee is this valve?
post #8 of 26 Old 09-29-2013, 04:57 AM Thread Starter
New brakes all the way around
YJSONLY is offline
post #9 of 26 Old 09-29-2013, 04:58 AM Thread Starter
Level is good. Brakes feel fine
YJSONLY is offline
post #10 of 26 Old 09-29-2013, 04:59 AM Thread Starter
Picture?
YJSONLY is offline
