UVCH replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-27-2013, 11:23 AM Thread Starter
UVCH replacement
I need to replace the passenger side UVCH because one of the connections has melted. I bought a DORMAN replacement gasket at O'Reilly's, but after reading some of the comments, I'm a bit skeptical about the product.
Upon closer examination, I see that the connectors are separate from the gasket itself, so I'm thinking that I'll be able to reuse the existing connectors (under the valve cover) and simply use the new gasket for the connections to the outer harness.
One of the outer connectors needs to be replaced as well (obviously) but there were two of them that came with the set, so that shouldn't be a problem.
What is the best way to splice in the new connectors?
Are crimp connections good enough or should I solder them?
Anything else I should be on the lookout for while I have the valve cover off?
What caused the connector to melt in the first place?
Thanks for any insight....
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 3 Old 09-27-2013, 11:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A short in the system or a wire grounding can cause that short, but inspect the wires inside the valve covers while your in there, never use crimp connectors for that stuff, it looks trashy for one and they pull apart easily as well, soder and use heat shrink you will have something to be proud of later
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 09-28-2013, 05:47 AM
Ranzan's Avatar
Quoted: 20 Post(s)
i depin my connectors and separate the wires from the pins themselves splicing works just as good but i am anal retentive
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
