Remove lift? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-27-2013, 10:13 AM Thread Starter
Remove lift?
Been looking for a couple months now for a CCLB and having a trouble getting one. My ? is how costly is it to removed a lift? Seems like half the trucks out there have at least 4" level lift or 6" lift. Is it just remove lift components and replace pitman arm or do you need all new springs, shocks, and spring, shock brackets. I know it depends on the kit, but how are majority done. Never saw much use for a lift as most people never take the truck off road and a 7000lb 20 ft long truck isn't the best off road vehicle. I need stock height as I carry a truck camper and actually haul stuff in the bed.
thanks in advance
Country Bumpkin is offline
post #2 of 2 Old 09-27-2013, 10:19 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Willing to bet someone would trade you straight up, or even add cash to boot, but it all depends on what components were used on the lift, such as sway bar extensions, blocks in the rear, springs, shocks, as well as the trac bar/mount and brake line extensions
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
