Replacement A/C compressor part number - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-27-2013, 10:37 AM Thread Starter
I'm getting ready to replace my A/C compressor but can't seem to get a straight answer on the part number that I need from any of the parts store. They are confused since the new body style light duty 250's came out the same year. Any ideas of what the actual part number should be?
1997 F-250 Powerstroke diesel
5 speed manual transmission
4x4 Off road package
FPR shim
DIY Tymar intake
GFS SVO system (runs awsome)
T-ROD is offline
post #2 of 3 Old 09-27-2013, 10:54 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Ford number is a 4R3Z19703A. If you are in no hurry buy from here and keep in mind that a '97HD is a parts counter jockeys worst nightmare. Always tell them it's a '96 (things only get tricky between '96 and '97 if you have a Cali model but not in the compressors case) and when looking for parts online also look for things under the same year Bronco and F150. :
1996 FORD F-250 Parts - AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 09-27-2013, 09:06 PM
m j
Ford F250 F350 SD 7 3L 94 98 AC A C Compressor KIT | eBay
those look like a good deal
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
