Rear brakes - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-24-2013, 02:45 PM Thread Starter
Rear brakes
Why does my rear brakes lock uo and slide whenever its raining .
Coreyroberts is offline
post #2 of 12 Old 09-24-2013, 04:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Because they need to be adjusted , or your rabs is out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 09-24-2013, 04:39 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Would like to know what you find I have same issue on my 97 barely touch pedal and lock my rears are 1k on shoes so I'm pretty sure it's not an adjustment problem
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 12 Old 09-24-2013, 04:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Just because the shoes are new does not mean they are not to tight
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 12 Old 09-24-2013, 08:20 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
because there is nothing on the rear end? for how big the brakes are the weight of the rear end is nothing , and cause its wet , my truck has done it around turns n such but my front ones have also locked up and slide
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #6 of 12 Old 09-24-2013, 08:57 PM
desertdeer's Avatar
Too tight and they lock up, too loose and they lock up, warped drums and they lock up, any fluid on the shoes and they lock up, not bled right they lock up.
Drum brakes are kinda picky. I would get a new hardware kit if you didn't already, make sure everything is correct, check for an axle seal leak or brake fluid leak, and lastly check the rabs valve.
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
post #7 of 12 Old 09-25-2013, 04:15 AM Thread Starter
Is there any disk brake kits available for my truck or some kind of diy kit
post #8 of 12 Old 09-25-2013, 04:56 AM
JSchuricht's Avatar
There are a few kits but they all have issues. The best method I have seen is using a 10.5 from a 99+ but then you have to deal with the metric lug pattern.
JSchuricht is offline
post #9 of 12 Old 09-25-2013, 06:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
1 guy used a 10.5 axle from and sd, re drilled the hubs, and used van rotors
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 12 Old 09-25-2013, 02:19 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i have a kit from blackbird custom trucks. they worked okay as a stock replacement. upgraded the booster to a hydrobooster setup and they are awesome. they still might lock up in the rain
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
