help with MAP sensor - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-22-2008, 04:18 AM Thread Starter
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
i heard that if u unplug the map sensor on an obs, you get a few more horses and black smoke.
anyway i went out to my truck, popped the hood, and was looking for where to unplug it (relative to a pic).
theres a square flat plug there, with a hose right beside it
kinda confused on what to do exactly, but does anyone have a write up on this? or pics
Typical cummins owner.
taylorking is offline
post #2 of 12 Old 06-22-2008, 07:39 AM Thread Starter
Too cool for school
taylorking's Avatar
cmon i just need to know if you unplug both the plug and the hose? just the plug? just the hose?
and i dont see how that plug is supposed to come out
post #3 of 12 Old 06-22-2008, 07:46 AM
KVFD
redstroker_2002's Avatar
ok taylor i did this last night. unplug that electric hook up. Then unclamp the hose and stick a bolt in it or a ink pen and clamp the bolt or ink pen tight and go drive I would recomment using a bolt and shove it far in there so you can clamp the hose back to the sensor just so it looks nice. the check engine light will turn on but it will smoke!!!!
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #4 of 12 Old 06-22-2008, 07:48 AM
KVFD
should be just a clip on there that you push and pull out its pretty easy! Good luck let me know what you think!
-Josh
post #5 of 12 Old 06-22-2008, 07:53 AM Thread Starter
Too cool for school
taylorking's Avatar
k im gonna go see wat i can do
post #6 of 12 Old 06-22-2008, 08:11 AM Thread Starter
Too cool for school
taylorking's Avatar
alright im pretty sure i know what to unplug. its square black plug with 3 wires coming out into a harness. the hose is directly to the right, on the same platform as the plug, correct?
is there a vacuum on that hose cause i dont want it to suck the pen into it lol. but what exactly does this mod do, in terms of fooling the computer? basically a boost fooler?
post #7 of 12 Old 06-22-2008, 02:44 PM Thread Starter
Too cool for school
taylorking's Avatar
tell me if i'm right ^^^
post #8 of 12 Old 06-22-2008, 03:05 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
there may be more smoke but i dnt see how any power gains are possible,if thepcm cany read boost there is no way to deliver correct fuel, i think it would hurt more than help power the way to do it correctly on an obs to fool the pcm is to take the center wire if im not misaking is green, and ground it to the body , that fools the pcm
ITS STOCK
SCUFFY828 is offline
post #9 of 12 Old 06-22-2008, 03:33 PM
monte psd's Avatar
wht does the green wire do?
DIRTY SOUTH STROKERS
95 F-350 psd 4" lift, 37x12.5x16.5 millitarys, Water meth stage 2, 3"down pipe, 4" exhaust, super single 7" stack, exhaust brake, 1.0 housing, intake, intercooled, 5 speed, ts 6 pos programer, 4:10 gears pos rear, CCV mod, FPR shimmed, 5.6K mod, gauges, smoke switch, dual steering stablelizers,
10000k HIDs SOLD
Monte
monte psd is offline
post #10 of 12 Old 06-22-2008, 06:51 PM Thread Starter
Too cool for school
taylorking's Avatar
i did it today and rode across town. probably same amount of smoke but actually less throttle response.
i didnt care for the check engine light lookin at me the whole time lol so i plugged her back in. i think this is intended for manual transmission trucks but mmine's auto)
